Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Forces from simpleFoam
Old   June 26, 2014, 07:47
Default Forces from simpleFoam
Sture Smidt
sture is on a distinguished road
This may have been covered before but:
-What is the reference density used by simpleFoam? I am analyzing a sphere in air at 10 m/s, but the stagnation pressure is 20% off. This may indicate that the density is treated as unity (1.0).
Are the simpleFoam results based on a density of unity?
sture is offline   Reply With Quote
Old   June 26, 2014, 09:34
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
there's no density in simpleFoam cause equations are divided by constant density and you're using kinematic viscosity. Surely miss in stagnation pressure can mean error in simpleFoam, but it equally (actually more likely) can be the error in your case setup.
alexeym is offline   Reply With Quote
Old   June 28, 2014, 18:00
Joachim Herb
jherb is on a distinguished road
Is your medium air (with density 1.2xx kg/m³)? In simpleFOAM the pressure used is p/rho, so this might explain the 20 % difference you see?
jherb is offline   Reply With Quote
Old   August 7, 2014, 14:41
Sture Smidt
How about forces from simpleFoam extracted with functionObjects? Are they normalized with the density like F=f/rho?
SS
Help! problems in calculating forces with SimpleFoam DLC OpenFOAM 3 April 25, 2022 23:43
interFoam vs. simpleFoam channel flow comparison DanM OpenFOAM Running, Solving & CFD 12 January 31, 2020 15:26
Forces for airfoil test case Martin_ OpenFOAM Running, Solving & CFD 1 July 2, 2012 11:58
Forces and drag coeffs in simpleFoam milos OpenFOAM Post-Processing 7 December 16, 2009 09:49
Adding coriolis forces in simplefoam Xabi OpenFOAM Running, Solving & CFD 1 April 24, 2009 04:43
