Home > Forums > OpenFOAM Post-Processing
how to probe a single velocity component using probeLocations
Old   August 15, 2014, 08:05
Default how to probe a single velocity component using probeLocations
Davide Lasagna
gasagna is on a distinguished road
I am using with success the utility probeLocations to probe the pressure field at selected points. Probing the velocity field also works in general, but I need only one of the velocity components. I could parse the generated file for post processing, but it would be more simple if i only get one velocity component only, as the resulting file would be simpler.
Is this possible?
Thanks,
Davide
gasagna is offline   Reply With Quote
Old   August 19, 2014, 11:53
Ontario
samieh is on a distinguished road
hi
i am trying to do the same job.would you please tell me how you did that? i want to calculate the pressure on some points on my column but i do not know the file which should be added in contdic
thanks alot
samieh is offline   Reply With Quote
Thread Tools
Trackbacks are On
Axisymmetric Case 3rd Velocity Component Mentalo OpenFOAM Running, Solving & CFD 2 June 8, 2014 12:45
Suspected division by zero on velocity reported by point probe dahicke STAR-CCM+ 1 July 4, 2013 02:16
Stn frame and radial velocity component in NREL mohammad CFX 1 October 25, 2011 10:13
sampling a strain-rate tensor single component vkrastev OpenFOAM Post-Processing 0 March 2, 2010 08:21
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
