Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
yPlusRAS utility - value for wall distance
Old   August 26, 2014, 10:47
Default yPlusRAS utility - value for wall distance
aylalisa is on a distinguished road
Dear Foamers,
I don't understand the value of the wall distance y that belongs to y+.
For example:
canal height h=0,2m
number of cells = 100, no grading --> cell height = 0,002m
I've assumed that yPlusRAS computes the y+ value of the first cell (center, closest to the wall) of the flow region.
Why is the appropriate wall distance 0 instead of 0,001m?
Thank's in advance for each response!
Ayla
aylalisa is offline   Reply With Quote
Old   September 1, 2014, 00:15
Andrew Rabbitt
Andy_RR is on a distinguished road
no idea, aylalisa, but this might give you some clues
Andy_RR is offline   Reply With Quote
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 02:36
Vertical distance from each cell to patch using modified yPlus utility? be_inspired OpenFOAM Programming & Development 2 June 10, 2019 04:59
[mesh manipulation] mirrorMesh utility preserving regions zfaraday OpenFOAM Meshing & Mesh Conversion 1 November 7, 2016 21:51
yPlusRAS used on SRF-case Tobias Adam OpenFOAM Post-Processing 1 April 7, 2014 08:09
Level set & distance functions Renato. Main CFD Forum 7 February 7, 2006 06:46
