Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
wallHeatFlux problem : maybe the unity
Old   February 20, 2015, 11:32
Default wallHeatFlux problem : maybe the unity
Laurent DASTUGUE
laurentD is on a distinguished road
Hi foamers,
i am currently trying to transfer results from an OF job to use them as inputs for another tool. This OF job is a CHTMultiRegionFoam one, with Fluid and Solid parts
The datas that i need are the heat flux from fluid to Solid.
So i have used wallHeatFlux, but when i use these results i am surprised because the other tool seems to say that these heat fluxes are too small to obrtain the OF results. And i have to trust him after having done some verifications.
So my first question is : what is the unity given by wallHeatFlux ?
And the second one is : Have you any ideas to solve my problem ?
Thanks for your reading,
have a good day,
LD
laurentD is offline   Reply With Quote
Old   March 2, 2015, 15:55
Alex
zfaraday will become famous soon enough
Hello Laurent,
Extracted from the utility output.
Time = 1001
Selecting thermodynamics package
    type            heRhoThermo;
    mixture         pureMixture;
    transport       sutherland;
    thermo          hConst;
    equationOfState perfectGas;
    specie          specie;
    energy          sensibleEnthalpy;
Selecting turbulence model type laminar
Wall heat fluxes [W]
patchName       value
Web site where I present my Master's Thesis: foamingtime.wordpress.com
The case I talk about in this site was solved with chtMultiRegionSimpleFoam solver and involves radiation. Some basic tutorials are also resolved step by step in the web. If you are interested in these matters, you are invited to come in!
zfaraday is offline   Reply With Quote
[Other] engineFoam new mesh problem ayhan515 OpenFOAM Meshing & Mesh Conversion 5 August 10, 2015 08:45
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
