Loading Cell Values in Tecplot
Hi everybody,
I am trying to use Tecplot 360 (2012R1) to post-process my openFoam solution. In this release of Tecplot, an openFoam data-loader is already existing, so I did not need to use any additional utility. The problem is the following: as long as I understood,the data-loader somehow interpolates the solution data to find the values of variable in the points (cell corners). That's kind of cool, but in my case, the approximation due to this interpolation is intolerable, and I need the exact cell values (which I consider the original openFoam solution). The problem is I cannot see the cell centre values in Tecplot anymore. In Paraview, you have the option to choose between cell values or point values. I wonder if there is any way to tackle this problem in Tecplot. (I can swithc to paraview, but I am very reluctant to give up Tecplot with all its advantages just because of this problem.) Any comment would be extremely appreciated. :) |
Any thoughts on that? Do you guys think I should post it on the main openFoam forum instead of post-processing forum?
Greetings P1361,
I'll address your questions a bit backwards. First of all: Quote:
Please follow the rules for the CFD-Online forums - http://www.cfd-online.com/Forums/misc.php?do=showrules - in this case in particular: Quote:
Let me go and search myself to see if I can find the posts about this... By using the following search sentence with Google: Code:
site:cfd-online.com "tecplot" openfoam center
Mmm... if all of the above fails, it looks like next step is to contact directly Scott Rumage, as he indicated in post #36 on this thread: http://www.cfd-online.com/Forums/ope...tml#post330364 Best regards, Bruno |
Heaps of thanks Bruno .. very complete and inclusive. Actually, I've seen some of these posts before, but couldn't solve the problem by them. I will give them a second try anyway.
All the best, ~p |
