Home > Forums > OpenFOAM Post-Processing
How can I calculate T gradient
Old   October 30, 2014, 11:13
sajad
sajad6 is on a distinguished road
hi
I make gradient boundry for T as below:
|  \\    /   O peration     | Version:  2.0.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    location    "0";
    object      gradient;
dimensions      [0 -1 0 1 0 0 0];
internalField   uniform (0,0,0);
boundaryField
    floor
        type            zeroGradient;
    ceiling
        type            zeroGradient;
    inlet
        type            fixedValue;
        value           uniform (0,0,0);
    outlet
        type            zeroGradient;
    block
        type            fixedValue;
        value           uniform (30,30,30);
    frontback
        type            empty;
but when I run your solution I face with this error:
|  \\    /   O peration     | Version:  2.1.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.1.0-0bc225064152
Exec   : wallGradT
Date   : Oct 30 2014
Time   : 18:43:10
Host   : "sajad-pc"
PID    : 13235
Case   : /home/sajad/Desktop/heatedCavity
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
--> FOAM FATAL IO ERROR:
wrong token type - expected Scalar, found on line 20 the punctuation token ','
file: /home/sajad/Desktop/heatedCavity/0/gradient::internalField at line 20.
    From function operator>>(Istream&, Scalar&)
    in file lnInclude/Scalar.C at line 91.
FOAM exiting
where is problem?
edit: How can I set boundry for gradientT?
edit 2: how can I calculate gradT in wall?
Last edited by wyldckat; November 1, 2014 at 15:45. Reason: posted a few minutes apart... and added [CODE][/CODE] markers
sajad6 is offline   Reply With Quote
Old   November 1, 2014, 15:48
Bruno Santos
wyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nice
Hi sajad6,
When it comes to OpenFOAM, every single detail, no matter how small, is more important than you might want to believe.
The error is related to the lines that are defined like this:
The correct way to do this in OpenFOAM is like this:
 value           uniform (0 0 0);
In other words, by using spaces instead of commas, for separating values in a vector.
Best regards,
Bruno
PS: When posting code and/our text output from a solver or utility, or the contents of a folder, please follow the instructions given here: Posting code and output with [CODE]
Thread Tools
Trackbacks are On
Gradient Computation: finite differences and adjoint method doan.nak SU2 1 June 24, 2014 16:37
calculate gradient tension in udf mohsenz_136 Fluent UDF and Scheme Programming 1 January 5, 2013 04:15
WSS and normal velocity gradient for the slanted pipe wanna88 FLUENT 2 October 1, 2012 22:34
Temperature Gradient at Wall sven OpenFOAM 7 November 1, 2010 18:25
calculate the temperature gradient on a profile arther FLUENT 0 April 19, 2006 23:12
