Home > Forums > OpenFOAM Post-Processing
How to decompose all time folders?
Like Tree1Likes
  • 1 Post By alexeym
Old   January 12, 2015, 12:14
Default How to decompose all time folders?
Sören Sander
Sören Sander is on a distinguished road
Hello Foamers,
how do I decompose all time steps in a given case folder and not only the start time?
E.g. my case is "case1". The folder already got precalculated time folders /0, /1, ... . Running decomposePar in a terminal will check for the start time written in the controlDict, e.g. "1" and decompose this time to the processeors. Is there any why to get the other times decomposed as well (e.g. "0", "2", ...)?
Sören Sander is offline   Reply With Quote
Old   January 12, 2015, 12:34
Alexey Matveichev
alexeym will become famous soon enoughalexeym will become famous soon enough
myself at daphne in ~$ decomposePar -help
Usage: decomposePar [OPTIONS]
options:
  -allRegions       operate on all regions in regionProperties
  -case <dir>       specify alternate case directory, default is the cwd
  -cellDist         write cell distribution as a labelList - for use with
                    'manual' decomposition method or as a volScalarField for
                    post-processing.
  -constant         include the 'constant/' dir in the times list
  -copyUniform      copy any uniform/ directories too
  -fields           use existing geometry decomposition and convert fields only
  -force            remove existing processor*/ subdirs before decomposing the
                    geometry
  -ifRequired       only decompose geometry if the number of domains has changed
  -latestTime       select the latest time
  -noFunctionObjects
                    do not execute functionObjects
  -noSets           skip decomposing cellSets, faceSets, pointSets
  -noZero           exclude the '0/' dir from the times list, has precedence
                    over the -zeroTime option
  -region <name>    specify alternative mesh region
  -time <ranges>    comma-separated time ranges - eg, ':10,20,40:70,1000:'
  -srcDoc           display source code in browser
  -doc              display application documentation in browser
  -help             print the usage
decompose a mesh and fields of a case for parallel execution
Using: OpenFOAM-2.3.0 (see www.OpenFOAM.org)
Build: 2.3.0-f5222ca19ce6
potentialFoam likes this.
alexeym is offline   Reply With Quote
Thread Tools
Trackbacks are On
Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Mesh Utilities 57 February 1, 2015 09:25
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 14:58
pisoFoam with k-epsilon turb blows up - Some questions Heroic OpenFOAM Running, Solving & CFD 26 December 17, 2012 04:34
AMI speed performance danny123 OpenFOAM 19 October 24, 2012 07:44
calculation diverge after continue to run zhajingjing OpenFOAM 0 April 28, 2010 04:35
