Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
reconstructPar with new TurbulentInletVelocity BC
Old   August 7, 2014, 09:40
Default reconstructPar with new TurbulentInletVelocity BC
Simon
Nomis is on a distinguished road
Dear foamers,
I implemented a new BC based on turbulentInlet.
Now I try to run this case parallel.
While reconstruct I get the following error message:
Reconstructing fields for mesh region0
Time = 1e-05
Reconstructing FV fields
Reconstructing volScalarFields
ddt0(p)
rho
alphaSgs
ddt0(thermosi,p)
kSGS
rho_0
p
ddt0(rho,K)
ddt0(rho)
T
ddt0(rho,h)
muSgs
Reconstructing volVectorFields
U
--> FOAM FATAL IO ERROR:
compound has already been transfered from token
on line 382697 the empty compound of type List<vector>
file: /home/itsnas/uxcih/3_OpenFOAM/uxcih-2.2.2/run/beta0_RefCase_L_5_Di_swirlRankineTurbulentVelocity Inlet_TEST_local/processor0/1e-05/U.boundaryField.SWIRLERINLET_11.value at line 382697.
From function token::transferCompoundToken(const Istream& is)
in file lnInclude/token.C at line 103.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::IOerror::abort() at ??:?
#2 Foam::token::transferCompoundToken(Foam::Istream const&) at ??:?
#3 Foam::Istream& Foam:perator>><Foam::Vector<double> >(Foam::Istream&, Foam::List<Foam::Vector<double> >&) at ??:?
#4 Foam::Field<Foam::Vector<double> >::Field(Foam::word const&, Foam::dictionary const&, int) at ??:?
#5 Foam::swirlRankineFlowRateTurbulentInletVelocityFv PatchVectorField::swirlRankineFlowRateTurbulentInl etVelocityFvPatchVectorField(Foam::fvPatch const&, Foam:imensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) at ~/8_Software_Openfoam/Einlass_RBen/swirlRankineFlowRateTurbulentInletVelocity/swirlRankineFlowRateTurbulentInletVelocityFvPatchV ectorField.C:107
#6 Foam::fvPatchField<Foam::Vector<double> >::adddictionaryConstructorToTable<Foam::swirlRank ineFlowRateTurbulentInletVelocityFvPatchVectorFiel d>::New(Foam::fvPatch const&, Foam:imensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) at /usr/local/share/OpenFOAM/OpenFOAM-2.2.2/src/finiteVolume/lnInclude/fvPatchField.H:142
#7 Foam::fvPatchField<Foam::Vector<double> >::New(Foam::fvPatch const&, Foam:imensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) at ??:?
#8 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::readField( Foam:imensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) at ??:?
#9 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::readFields(Foam::dictionary const&) at ??:?
#10 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::readFields() at ??:?
#11 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject const&, Foam::fvMesh const&) at ??:?
#12
at ??:?
#13
at ??:?
#14
at ??:?
#15 __libc_start_main in "/lib64/libc.so.6"
#16
at /usr/src/packages/BUILD/glibc-2.11.3/csu/../sysdeps/x86_64/elf/start.S:116
Abbruch
Exitcode 134
decompose and the solver itsself run without any error message.
The solver writes perfect U files for every processor.
I also tried different decompose methods (scotch, simple) but still get the same error message.
Running the case with one processor over little time shows no problems.
The new bc is used on patch SWIRLERINLET_11.
So this might be the problem ;-)
There have been no errors while compiling the new bc.
Does anybody know what is wrong with the function token::transferCompoundToken(const Istream& is) in token.C?
Thanks a lot in advance!
Simon
Nomis is offline   Reply With Quote
Old   December 2, 2015, 17:58
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
Hi Simon,
I know this is an old post but did you figure out a solution to this error?
I am getting the same thing with a new custom boundary condition and I am not sure what the problem is.
Does your new boundary condition use an interpolationTable by any chance?
Best regards,
Philip
bigphil is offline   Reply With Quote
reconstructPar --> fileName::stripInvalid() called for invalid fileName commandtouse adona058 OpenFOAM Bugs 34 December 8, 2022 21:27
reconstructPar does not work in interDyMFoam ageorg OpenFOAM Post-Processing 4 April 15, 2016 13:25
Problem with reconstructPar: "First token could not be read" quartzian OpenFOAM Post-Processing 2 October 22, 2015 02:40
reconstructPar and a high number of snapshots fs82 OpenFOAM Programming & Development 2 April 18, 2012 04:37
Problem with reconstructPar fabianpk OpenFOAM 5 August 14, 2007 09:17
