problem to calculate yplus in moving mesh
Hi all,
I am currently running moving Cylinder with pimpleDyMFoam. I runned it in serial (one core) and then I could get the amount of yPlus in each time step. But the problem is that when I run the tutorial in parallel and I want to calculate yplus the following error appeared on the terminal. --> FOAM FATAL ERROR: Face zone name frontOutZone for GGI patch frontOut not found. Please check your GGI interface definition. From function label ggiPolyPatch::zoneIndex() const in file meshes/polyMesh/polyPatches/constraint/ggi/ggiPolyPatch.C at line 675. FOAM aborting Aborted (core dumped) Could any body help me in this problem? Many thanks for the attention |
