March 3, 2015, 18:48 |
how use the result data as initial data
songbo
Rep Power: 11 |
I have finished a simulation of a case, and I have the result data in result files. Now I want to simulate the same case with very small time step from the result conditions. is it possible? Could anyone help me? |
March 4, 2015, 02:01 |
If you plan to use the same solver, you can run simulation in the same folder, just set startTime to latestTime in controlDict. Or you can create new case folder and use mapFields utility to map old simulation results to new one. |
Display Modes | |
CFD by anderson, chp 10.... supersonic flow over flat plate | varunjain89 | Main CFD Forum | 18 | May 11, 2018 07:31 |
Simulation seems to converge but crashes suddenly | xxxx | OpenFOAM | 16 | September 12, 2014 08:07 |
rhoSimplecFoam Mach0.8 no pressure values | CFDnewbie147 | OpenFOAM Running, Solving & CFD | 16 | November 23, 2013 05:58 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 13:58 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 08:35 |
