Fast way to delete some files in some folders... |
April 23, 2015, 10:51 |
Dongyue Li
Rep Power: 17 |
Hey guys,
I use backward scheme in ddt term. After running, in every timestep I have U and U_0 and k and k_0 sth like this. How can I delete all xxx_0 in every time step? I just want to save this project for no purpose...But its quite large! Thanks! |
April 23, 2015, 14:51 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: If you delete these fields, you won't be able to continue at a later time. Anyway, using bash/sh, you should be able to use this command:
rm [0-9]*/*_0 Code:
find . -name "*_0" | xargs rm |
The udf.h headers are unable to open- in VISUAL STUDIO 13 | sanjeetlimbu | Fluent UDF and Scheme Programming | 4 | May 2, 2016 05:38 |
UDF help for Rapid compression machine ECM. | sanjeetlimbu | Fluent UDF and Scheme Programming | 0 | March 17, 2015 22:45 |
How to run a series of Fluent journal files in order? | jyoung79 | FLUENT | 2 | September 22, 2014 08:52 |
Writing Case and Data Files Using Journal/Scheme Files | svp | Fluent UDF and Scheme Programming | 0 | April 5, 2011 11:04 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
