[PyFoam] doesn't plot residuals
Old   June 16, 2015, 11:36
Default doesn't plot residuals
immortality's Avatar
Ehsan
immortality is on a distinguished road
Hi everyone,
when I want to run my case in 2.4.0 version of OF by this command as I had done before in 2.2.2 version
pyFoamPlotRunner.py --hardcopy --with-deltat --with-courant --procnr=4 rhoCentralFoamGasCont
this warning is shown and although it runs successfully but doesn't plot residuals as before
 PyFoam WARNING on line 142 of file /usr/local/lib/python2.7/dist-packages/PyFoam-0.6.4-py2.7.egg/PyFoam/LogAnalysis/GeneralLineAnalyzer.py : Problem doing timelines could not convert string to float:
Time = 1.8007576e-05
what could be the reason?
thanks a lot.
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   June 22, 2015, 03:48
Ehsan
that error has resolved,now another error on gnuplot is shown, the graphs are written to disc but don't show while running the case.
 PyFoam WARNING on line 144 of file /usr/local/lib/python2.7/dist-packages/PyFoam-0.6.4-py2.7.egg/PyFoam/Execution/ParallelExecution.py : which can not find a match for rhoCentralFoamGasCont . Hoping for the best
gnuplot> set terminal x11
         line 0: unknown or ambiguous terminal type; type just 'set terminal' for a list
gnuplot> set terminal x11 noraise
^Z
[3]+  Stopped                 runPlot 4 rhoCentralFoamGasCont
Old   June 27, 2015, 17:25
Jason Dale
jason is on a distinguished road
I also get a similar error on Ubuntu 14.04.2 and OpenFOAM 2.4.0, if I type gnuplot and then set terminal the x11 type is not listed
Any luck finding what's wrong? Maybe I will try an earlier version of gnuplot.
Br
one-think@ubuntu:~/OpenFOAM/one-think-2.4.0/run/tutorials/incompressible/simpleFoam/pitzDaily$ pyFoamPlotRunner.py simpleFoam
| \\ / O peration | Version: 2.4.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 2.4.0-f0842aea0e77
Exec : simpleFoam
Date : Jun 27 2015
Time : 22:18:13
Host : "ubuntu"
PID : 75673
Case : /home/one-think/OpenFOAM/one-think-2.4.0/run/tutorials/incompressible/simpleFoam/pitzDaily
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting RAS turbulence model kEpsilon
kEpsilonCoeffs
Cmu 0.09;
C1 1.44;
C2 1.92;
sigmaEps 1.3;
No finite volume options present
SIMPLE: convergence criteria
field p tolerance 0.01
field U tolerance 0.001
field "(k|epsilon|omega)" tolerance 0.001
Starting time loop
streamLine streamLines:
automatic track length specified through number of sub cycles : 5
Time = 1
smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 0.0259999, No Iterations 1
smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 0.0552193, No Iterations 1
GAMG: Solving for p, Initial residual = 1, Final residual = 0.0940796, No Iterations 22
time step continuity errors : sum local = 1.64619, global = -0.314315, cumulative = -0.314315
smoothSolver: Solving for epsilon, Initial residual = 0.10353, Final residual = 0.00344963, No Iterations 2
smoothSolver: Solving for k, Initial residual = 1, Final residual = 0.0392021, No Iterations 2
ExecutionTime = 0.21 s ClockTime = 1 s
jason is offline   Reply With Quote
Old   June 28, 2015, 08:43
Jason Dale
Ok, so if you install gnuplot and then install gnuplot-x11 it then works ok. gnuplot-x11 is the driver to plot to the terminal and its not included in the main gnuplot package.
Doh.
Old   June 28, 2015, 10:13
Ehsan
type this in terminal:
sudo apt-get install gnuplot-x11
[Tutorials] Tutorial of how to plot residuals ! wolle1982 OpenFOAM Community Contributions 171 February 20, 2024 02:55
How to plot residuals vs iterations using pyFoam... ata313ata Visualization & Post-Processing 1 February 6, 2018 04:34
Plot the residuals over all the domain Douglas OpenFOAM Post-Processing 0 June 27, 2017 16:01
plot residuals pigna OpenFOAM Running, Solving & CFD 2 December 19, 2014 02:32
How to plot residuals of all iterations in Fluent FJSJ FLUENT 4 September 20, 2013 09:47
