Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
wallHeatFlux crashes: "not implemented"
Like Tree1Likes
  • 1 Post By Dozer_94
Old   August 5, 2015, 07:07
Default wallHeatFlux crashes: "not implemented"
buffi is on a distinguished road
I tried to run wallHeatFlux on one processor mesh of a decomposed case. The error message indicates that something is "not implemented", but I don't know if this is a suitable description of the actual problem, or what exactly isn't implemented:
-bash-4.1$ wallHeatFlux -region inner
|  \\    /   O peration     | Version:  2.3.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.3.1-262087cdf8db
Exec   : wallHeatFlux -region inner
Date   : Aug 05 2015
Time   : 11:59:14
Host   : "bombus"
PID    : 712
Case   : /work/tt/ttcr/test_18x6_ht_kOmegaSST_148568_postProcessing/processor0
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh inner for time = 10000
Time = 10000
Selecting thermodynamics package
    type            heRhoThermo;
    mixture         pureMixture;
    transport       const;
    thermo          hConst;
    equationOfState rhoConst;
    specie          specie;
    energy          sensibleEnthalpy;
Selecting turbulence model type RASModel
Selecting RAS turbulence model kOmegaSST
--> FOAM FATAL ERROR:
Not implemented
    From function processor::coupledFvPatchField<Type>::snGrad()
    in file lnInclude/coupledFvPatchField.H at line 153.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) in "/nfs/rzpool/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1  Foam::error::abort() in "/nfs/rzpool/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2  Foam::coupledFvPatchField<Foam::Vector<double> >::snGrad() const in "/nfs/rzpool/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#3  Foam::fv::gaussGrad<Foam::Vector<double> >::correctBoundaryConditions(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh>&) in "/nfs/rzpool/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#4  Foam::fv::gaussGrad<Foam::Vector<double> >::calcGrad(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::word const&) const in "/nfs/rzpool/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#5  Foam::fv::gradScheme<Foam::Vector<double> >::grad(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::word const&) const in "/nfs/rzpool/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/libcompressibleTurbulenceModel.so"
#6  Foam::tmp<Foam::GeometricField<Foam::outerProduct<Foam::Vector<double>, Foam::Vector<double> >::type, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::grad<Foam::Vector<double> >(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&) in "/nfs/rzpool/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/libcompressibleTurbulenceModel.so"
#7  Foam::compressible::RASModels::kOmegaSST::kOmegaSST(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::fluidThermo const&, Foam::word const&, Foam::word const&) in "/nfs/rzpool/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so"
#8  Foam::compressible::RASModel::adddictionaryConstructorToTable<Foam::compressible::RASModels::kOmegaSST>::New(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::fluidThermo const&, Foam::word const&) in "/nfs/rzpool/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so"
#9  Foam::compressible::RASModel::New(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::fluidThermo const&, Foam::word const&) in "/nfs/rzpool/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so"
#10  Foam::compressible::turbulenceModel::addturbulenceModelConstructorToTable<Foam::compressible::RASModel>::NewturbulenceModel(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::fluidThermo const&, Foam::word const&) in "/nfs/rzpool/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so"
#11  Foam::compressible::turbulenceModel::New(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::fluidThermo const&, Foam::word const&) in "/nfs/rzpool/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/libcompressibleTurbulenceModel.so"
#12
 in "/nfs/rzpool/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/bin/wallHeatFlux"
#13  __libc_start_main in "/lib64/libc.so.6"
#14
Abgebrochen (Speicherabzug geschrieben)
What can cause this error and is there a way around it?
I'm trying to run post processing utilities on a decomposed case because the mesh is large (50M) and I don't want to create 100 subsetMeshes because that would take a week only for creating the meshes.
Regards
Christoph
buffi is offline   Reply With Quote
Old   August 2, 2019, 11:18
Dozer_94 is on a distinguished road
Hi Christoph,
Very old thread, but did you manage to find a solution?
sourav90 likes this.
Dozer_94 is offline   Reply With Quote
wallHeatFlux utility with sonicFoam hiuluom OpenFOAM Post-Processing 3 September 18, 2015 07:39
how to use wallHeatFlux for incompressible problem? hswzzz OpenFOAM Post-Processing 1 April 14, 2015 06:25
Something doens't work with wallHeatFlux utility or externalWallHeatFluxTemperat BC!! zfaraday OpenFOAM Post-Processing 0 February 5, 2015 16:47
problem with WallHeatFlux Roman1 OpenFOAM Running, Solving & CFD 1 January 24, 2014 10:31
flo-efd v11.0.0 crashes YoavF FloEFD, FloWorks & FloTHERM 3 June 21, 2012 12:37
