August 6, 2015, 07:33 |
sample on an inclined line
SM
Rep Power: 15 |
Is it somehow possible using sampleDict to sample on a straight but inclined line at certain distance from a patch?
Say for example along the expanding wall of diffuser at particular distance from the wall or at first cell height? someway to use Code:
somePatchPoints Last edited by canopus; August 6, 2015 at 09:10. |
August 16, 2015, 15:12 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings canopus,
Sorry, but I didn't understand your question. Are you asking about how to generate the list of points that are at a certain distance from a patch? So that the list can then be provided to the sampling entry? For other readers, canopus was referring to this entry: Code:
somePatchPoints { // Sample nearest points on selected patches. Looks only up to // maxDistance away. Any sampling point not found will get value // pTraits<Type>::max (usually VGREAT) // Use with interpolations: // - cell (cell value) // - cellPatchConstrained (boundary value) // - cellPoint (interpolated boundary value) type patchCloud; axis xyz; points ((0.049 0.099 0.005)(0.051 0.054 0.005)); maxDistance 0.1; // maximum distance to search patches (".*Wall.*"); } Best regards, Bruno
[Gmsh] 3D Mesh conversion from gmsh-2.5.0 to OpenFOAM | Ancioi | OpenFOAM Meshing & Mesh Conversion | 17 | January 8, 2019 23:50 |
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' | muth | OpenFOAM Running, Solving & CFD | 3 | August 27, 2018 04:18 |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
[Gmsh] boundaries with gmshToFoam | ouafa | OpenFOAM Meshing & Mesh Conversion | 7 | May 21, 2010 12:43 |
Problems of Duns Codes! | Martin J | Main CFD Forum | 8 | August 14, 2003 23:19 |
