binData with pimpleDyMFoam
In order to get the span-wise distribution of aerodynamic forces on a circular cylinder subjected to vortex induced vibration, I used the following piece of code in my controlDict
binData With this code, error soon appears when running with pimpleDyMFoam: Code:
#0 Foam::error::printStack(Foam::Ostream&) at ??:? Also in the static cylinder case, for which pimpleFoam is used, the binData function works well. Does binData function not support dynamicMesh? |
Quick question/answer: Which OpenFOAM version are you using? Because there was a bug related to this in 2.3.0... the bug report: http://www.openfoam.org/mantisbt/view.php?id=1560
dear Bruno
I'm using OF2.3.0. I will try the later versions. Thanks! |
Yes! OF2.4.0 works well for bindata with pimpleDyMFoam!
