Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
yPlusRAS error: "cannot open file"
Old   September 8, 2015, 06:45
Default yPlusRAS error: "cannot open file"
jaydeep
jaydeepKhajure is on a distinguished road
Currently I am running the case in OpenFOAM 2.3.0. I am having a problem calculating the y plus value. My case is in sonicfoam having Re 3e6 and I am using K-Epsilon RAS model. However, after post processing I type the command yPlusRAS in terminal, I get following error message,
Create time
Create mesh for time = 0
Time = 0
Calculating wall distance
Writing wall distance to field y
Reading field U
--> FOAM FATAL IO ERROR:
cannot open file
file: /home/cae/OpenFOAM/cae-2.3.0/run/jaydeep/Pen_3D_4.5/constant/transportProperties at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 87.
FOAM exiting
Can anybody suggest a possible solution to overcome this error message ?
Thanks and Regards
jaydeep
[ Moderator note: moved post from http://www.cfd-online.com/Forums/ope...-values-2.html and deleted the duplicate posts. ]
jaydeepKhajure is offline   Reply With Quote
Old   September 8, 2015, 06:51
romant's Avatar
Roman Thiele
romant is on a distinguished road
Create time
Time = 0
Reading field U
cannot open file
FOAM exiting
Thanks and Regards
jaydeep
Your problem has nothing to do with the thread which has been tried to solve here. Please open a new thread for your problems or try to find similar threads. Also, by posting multiple times you make forum threads unreadable. This forum is supported by volunteers, which will help when they have time and there is no need to post multiple times to speed up the process.
BTW, when you read your error message carefully you will see that you are missing a file which the solver needs to read. In your case transportProperties.
~roman
romant is offline   Reply With Quote
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 17:18
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 06:42
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 01:41
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 13:59
