Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
PostChannel in parallel
Old   May 29, 2006, 06:53
Default I'm postprocessing big data in
Maka Mohu
maka is on a distinguished road
I'm postprocessing big data in parallel with postChannel utility. I noticed that postChannel does not work in parallel and breaks with the following error. I tried to run postChannel on tutorial case Channel395 and it gave the same error. My guess is that the code responsible for collapsing the field does not work in parallel since it needs to communicate with other processors to do the collapsing. I tried to force the code to collapse the fields at the end, and it only broke at the end, which means averaging works well in parallel. Can any body help solving this problem?
here is the error message:
Create time
Create mesh for time = 120
Reading transportProperties
Collapsing fields for time constant
Collapsing fields for time 40
One of the processes started by mpirun has exited with a nonzero exit
code. This typically indicates that the process finished in error.
If your process did not finish in error, be sure to include a "return
0" or "exit(0)" in your C code before exiting the application.
PID 19000 failed on node n1 (192.168.192.20) due to signal 11.
best regards,
Maka
maka is offline   Reply With Quote
Old   May 30, 2006, 05:37
Default Also nAveragingSteps.raw is no
Maka Mohu
Also nAveragingSteps.raw is not copied by reconstructPar to the reconstructed folder and has to be copied manually. This refers to V 1.2.
regards,
Maka
Old   November 4, 2015, 23:05
Manjura Maula Md. Nayamatullah
mmmn036 is on a distinguished road
I had the similar problem to run postChannel in parallel as my mesh is very fine with huge mesh points. Does any body how the postChannel will work in parallel or within simulation run?
I would appreciate any suggestions.
Thanks
MMMN
mmmn036 is offline   Reply With Quote
PostChannel utility not working in OpenFoam 15 nishant_hull OpenFOAM Running, Solving & CFD 15 January 18, 2012 05:26
PostChannel maka OpenFOAM Post-Processing 5 July 22, 2009 09:15
PostChannel maka OpenFOAM Bugs 4 April 21, 2009 14:14
PostChannel Utility in openfoam15 not working nishant_hull OpenFOAM Bugs 0 August 14, 2008 15:49
Parallel postChannel from within channelOodles for DNS and LES maka OpenFOAM Running, Solving & CFD 1 February 18, 2008 13:08
