Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Is there a code for yPlusRAS or LES for low-Re (no wall function)
Like Tree1Likes
  • 1 Post By wc34071209
Old   December 12, 2015, 05:52
Default Is there a code for yPlusRAS or LES for low-Re (no wall function)
Seokwon Whang
hswzzz is on a distinguished road
Dear all,
I think in OF 230, there is no yPlus utility for low-Re-number model.
And I found some codes for previous version. (not work in version 230)
Is there a code for yPlusRAS or LES for low-Re-number ?
hswzzz is offline   Reply With Quote
Old   December 15, 2015, 03:28
Sören Sander
Sören Sander is on a distinguished road
The utility is yPlusRAS or yPlusLES. If you have no wall functions it is also possible to calculate y+ at the walls by using wallGradU.
Sören Sander is offline   Reply With Quote
Old   December 15, 2015, 20:17
Seokwon Whang
Thank you for your reply.
However, when I try with 'yPlusRAS', y+ = zero.
I used 'buoyantBoussinesqP(S)impleFoam' with k-w SST model(wall resolved model)
Old   December 16, 2015, 05:17
Sören Sander
A quick solution might be to use wallGradU and use the paraview calculator utility to get y+ as
y+ = y * sqrt(wallGradU / nu)
Old   December 16, 2015, 08:54
Seokwon Whang
Thank you ! I will try it!
Old   May 6, 2017, 10:15
Yuehan
wc34071209 is on a distinguished road
I made a version of yPlusRAS utility which calculates y+ based on wallGradU. It is for OpenFOAM 2.3.
The code is here
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     |
    \\  /    A nd           | Copyright (C) 2011-2013 OpenFOAM Foundation
     \\/     M anipulation  |
License
    This file is part of OpenFOAM.
    OpenFOAM is free software: you can redistribute it and/or modify it
    under the terms of the GNU General Public License as published by
    the Free Software Foundation, either version 3 of the License, or
    (at your option) any later version.
    OpenFOAM is distributed in the hope that it will be useful, but WITHOUT
    ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
    FITNESS FOR A PARTICULAR PURPOSE.  See the GNU General Public License
    for more details.
    You should have received a copy of the GNU General Public License
    along with OpenFOAM.  If not, see <http://www.gnu.org/licenses/>.
Application
    yPlusRAS
Description
    Calculates and reports yPlus for all wall patches, for the specified times
    when using RAS turbulence models.
    Default behaviour assumes operating in incompressible mode.
    Use the -compressible option for compressible RAS cases.
#include "fvCFD.H"
#include "incompressible/singlePhaseTransportModel/singlePhaseTransportModel.H"
#include "incompressible/RAS/RASModel/RASModel.H"
#include "fluidThermo.H"
#include "compressible/RAS/RASModel/RASModel.H"
#include "wallDist.H"
#include "wallFvPatch.H"
void calcIncompressibleYPlus
    const fvMesh& mesh,
    const Time& runTime,
    const volVectorField& U,
    volScalarField& yPlus
    #include "createPhi.H"
    singlePhaseTransportModel laminarTransport(U, phi);
    autoPtr<incompressible::RASModel> turbulence
        incompressible::RASModel::New(U, phi, laminarTransport)
    const incompressible::RASModel& model = turbulence;
    // Turbulence patch field
    const volScalarField nu(model.nu());
    const volScalarField::GeometricBoundaryField& nuPatches =
        nu.boundaryField();
    // U patch field
    const volVectorField::GeometricBoundaryField& UPatches =
        U.boundaryField();
    // yPluse patch field
    volScalarField::GeometricBoundaryField& yPlusPatches =
        yPlus.boundaryField();
    bool foundPatch = false;
    const fvPatchList& patches = mesh.boundary();
    forAll(UPatches, patchi)
        foundPatch = true;
        if (isA<wallFvPatch>(patches[patchi]))
            const fvPatchScalarField& nu_ = nuPatches[patchi];
            const fvPatchVectorField& U_ = UPatches[patchi];
            fvPatchScalarField& yPlus_ = yPlusPatches[patchi];
            const scalarField& y_ = model.y()[patchi];
            yPlus_ = y_ * Foam::pow((mag(U_.snGrad())/nu_),0.5);
            scalar minYp = gMin(yPlus_);
            scalar maxYp = gMax(yPlus_);
            scalar avgYp = gAverage(yPlus_);
            scalar minY = gMin(y_);
            scalar maxY = gMax(y_);
            scalar avgY = gAverage(y_);
            if (Pstream::master())
                Info<< patches[patchi].name() << endl
                    << "    y+ : min = " << minYp << ", max = " << maxYp
                    << ", average = " << avgYp << nl
                    << "    y : min = " << minY << ", max = " << maxY
                    << ", average = " << avgY << endl;
    if (!foundPatch)
        Info<< "    no " << wallFvPatch::typeName << " patches"
            << endl;
void calcCompressibleYPlus
    const fvMesh& mesh,
    autoPtr<fluidThermo> pThermo
        fluidThermo::New(mesh)
    fluidThermo& thermo = pThermo();
    volScalarField rho
        IOobject
            "rho",
            runTime.timeName(),
            mesh
        thermo.rho()
    #include "compressibleCreatePhi.H"
    autoPtr<compressible::RASModel> turbulence
            rho,
            U,
            phi,
            thermo
    const compressible::RASModel& model = turbulence;
    const volScalarField::GeometricBoundaryField& rhoPatches =
        model.rho().boundaryField();
    const volScalarField::GeometricBoundaryField& muPatches =
        model.mu().boundaryField();
    // U patch field
        U.boundaryField();
        foundPatch = true;
            const fvPatchScalarField& rho_ = rhoPatches[patchi];
            const fvPatchScalarField& mu_ = muPatches[patchi];
            yPlus_ = y_ * Foam::pow((mag(U_.snGrad())/(mu_/rho_)),0.5);
    if (!foundPatch)
            << endl;
int main(int argc, char *argv[])
    timeSelector::addOptions();
    #include "addRegionOption.H"
    argList::addBoolOption
        "compressible",
        "calculate compressible y+"
    #include "setRootCase.H"
    #include "createTime.H"
    instantList timeDirs = timeSelector::select0(runTime, args);
    #include "createNamedMesh.H"
    const bool compressible = args.optionFound("compressible");
    forAll(timeDirs, timeI)
        runTime.setTime(timeDirs[timeI], timeI);
        Info<< "Time = " << runTime.timeName() << endl;
        fvMesh::readUpdateState state = mesh.readUpdate();
        // Wall distance
        if (timeI == 0 || state != fvMesh::UNCHANGED)
            Info<< "Calculating wall distance\n" << endl;
            wallDist y(mesh, true);
            Info<< "Writing wall distance to field " << y.name() << nl << endl;
            y.write();
        volScalarField yPlus
            IOobject
                "yPlus",
                runTime.timeName(),
                mesh,
                IOobject::NO_READ,
                IOobject::NO_WRITE
            mesh,
            dimensionedScalar("yPlus", dimless, 0.0)
        IOobject UHeader
            "U",
            runTime.timeName(),
            mesh,
            IOobject::MUST_READ,
            IOobject::NO_WRITE
        if (UHeader.headerOk())
            Info<< "Reading field U\n" << endl;
            volVectorField U(UHeader, mesh);
            if (compressible)
                calcCompressibleYPlus(mesh, runTime, U, yPlus);
            else
                calcIncompressibleYPlus(mesh, runTime, U, yPlus);
        else
            Info<< "    no U field" << endl;
        Info<< "Writing yPlus to field " << yPlus.name() << nl << endl;
        yPlus.write();
    Info<< "End\n" << endl;
    return 0;
Aaron_L likes this.
wc34071209 is offline   Reply With Quote
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 06:42
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
