Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Recalculate functionObjects
Old   February 18, 2016, 07:29
Default Recalculate functionObjects
Soeren Werner
wersoe is on a distinguished road
Hi foamers,
I did run a couple of long-lasting transient simulation and now I d like to recalculated forces and moments on patches since I did a mistake on the moment centre.
How can I recalculate the functionsObject only, based on timeStep data wich is available.
Thanks,
Sören
wersoe is offline   Reply With Quote
Old   February 18, 2016, 12:14
Olivier
olivierG is on a distinguished road
The utility "execFlowFunctionObjects" is your friend.
NB: you may need to add the "readFields" object if you need to load some other Filed like T, ...), see wiki, and the "-dict" option may be an option.
regards,
olivier
olivierG is offline   Reply With Quote
Old   February 19, 2016, 02:33
Soeren Werner
Thank you very much - exactly what I did not found
'functionObjects' or 'sample' on a mesh pointSet Luke.12 OpenFOAM Post-Processing 0 January 15, 2016 10:28
Reading in foamFiles from functionObjects Adam_Lavely OpenFOAM Post-Processing 0 July 17, 2013 13:37
Problem with functionObjects in parallel anishtain4 OpenFOAM 4 February 12, 2013 05:27
OpenFOAM v1.6 & OpenMPI & functionObjects bruce OpenFOAM Bugs 7 December 16, 2011 14:37
OpenFOAM v1.6 & OpenMPI & functionObjects bruce OpenFOAM Running, Solving & CFD 1 August 7, 2009 13:15
