Error when executing paraFoam
Dear members
I developed a new solver and a case based on reactingFoam. When I want to run paraFoam it within the case directory it gives the following error created temporary 'particle.OpenFOAM' fileName::stripInvalid() called for invalid fileName H2(copy)~ For debug level (= 2) > 1 this is considered fatal Aborted (core dumped) I checked the case folder several times but it does not contain any H2 file or invalid file name. I referred the other threads related to this but I couldn't find solution |
In my limited experience, I have noticed that this almost always corresponds to having a space in the folder name or file name. You might want to check on that. Cheers, Antimony |
Hi
I'v found the solution. There were some hidden files in the directory. After deleting that problem was solved. Thanks |
