Monitoring Volume Average of Liquid Velocity Magnitude in a Bubble Column / Airlift |
February 26, 2013, 10:52 |
Kevin
Rep Power: 14 |
Hi there,
I´m fairly new to openFoam, but I know that there is a swak4foam utility that helps solving some minor problems. What I want to do is to monitor the Volume Average of a defined region of an airlift reactor over the flow time so I can see when the system reaches quasi steady state. In Fluent there are the "Monitors" which allow that feature - a textfile containing the flowtime and the volumeaverage of the water velocity magnitude of a defined region/volume is written and appended after each timestep of that transient simulation. The head region of the airlift reactor is not needed, because here the water velocity changes to much because of bubbles bursting at the water/air interface. Instead it would be enough to patch a region from the bottom/sparger until maybe 10 mm underneath the water level. Then a volume average of the water velocity magnitude of that patch shall be written into a text file along with the current flow time. This allows to be plotted XY. Finally this shows how long a simulation need until a quasi steady state is reached. I guess its very simple code using swak4foam... I just never haved used it and are also very new to openfoam, so I would be very glad if somebody could give those 10? lines of code along a short tutorial what to do else to the openfoam case to make this work. Thx in advance Kevin |
February 26, 2013, 18:01 |
#2 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
The general mechanism for such "monitors" in OpenFOAM are functionObjects: small plugin-programs that are executed at the end of each timestep. swak4foam happens to implement some. So what you want is monitor the velocity magnitude in a subvolume of the mesh. How you do that depends on whether the sub-volume is defined in the mesh by a cellSet or a cellZone. In that case a swak-functionObject like (I'm doing this off the top of my head. There my be typos or involuntary omissions) this could do it: Code:
waterVel { type swakExpression; valueType cellSet; setName kevinsSet; expression "mag(U)*alpha1*vol()/(alpha1*vol())"; accumulations ( sum ); verbose true; } Code:
waterVel { type swakExpression; valueType internalField; variables ( "validVol=pos().z<-0.01 ? vol() : 0;" ); expression "mag(U)*alpha1*validVol/(alpha1*validVol)"; accumulations ( sum ); verbose true; }
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
February 27, 2013, 10:26 |
Kevin
Rep Power: 14 |
Hey there Gschaider. Thx for your swift answer.
By Volume Average I mean the value of the Water Velocity Magnitude of each cell divided by the number of cells in the region of interest which brings me to the expression "patch" I used but what I meant is a defined reagion which is somewhat smaller than the whole computational domain/airlift reactor. (There is a function in Fluent "adapt -> region..." and then you can for example patch air to the headspace for initial condition - thats kinda what I meant. ) |
March 1, 2013, 05:57 |
#4 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
May 19, 2016, 05:59 |
thomas
Rep Power: 11 |
do you have any experiences with foamMonitor? Why do you prefer this alternative instead of the foamMonitor one? Thanks in advance! |
[DesignModeler] Bubble column / Airlift Reactor with separate headspace | kevinlipps | ANSYS Meshing & Geometry | 1 | March 21, 2012 07:56 |
velocity of air | Robert | Main CFD Forum | 4 | January 22, 2007 18:42 |
Query on VOF for Bubble rise | Vamsi | Main CFD Forum | 0 | December 22, 2005 00:02 |
Variables Definition in CFX Solver 5.6 | R P | CFX | 2 | October 26, 2004 02:13 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
