[swak4Foam] OF 3.0.0 cluster install problems
Old   July 18, 2016, 12:23
Default OF 3.0.0 cluster install problems
Matt
fatirishman53 is on a distinguished road
It is completely possible that I am dumb and/or blind, but I can't seem to find a solution to this problem:
I am working on a CentOS 6.2 cluster system that has OpenFOAM-2.3.x and OpenFOAM-3.0.0 installed.
I have sucessfully installed swak4Foam on my personal computer for OpenFOAM-3.0.0.
I have successfully installed swak4Foam for 2.3.x within the cluster system at "$HOME/OpenFOAM/$USER-2.3.x".
However, when following the same procedure within the cluster system at "$HOME/OpenFOAM/$USER-3.0.0", I get the errors within the make.log file attached to this post. (I ensured that I sourced "$WM_PROJECT_INST_DIR/OpenFOAM-3.0.0/etc/bashrc")
I used "openfoam-extend-swak4Foam-dev-master" as the installation source for 3.0.0.
The first thing that catches my eye is "No swak4FoamParsers/foamVersion4swak.H. Generated" followed by a slew of "could not open file * for source file * due to Permission denied". Yet, the permissions are no different that the OpenFOAM-2.3.x installation.
Any help would be appreciated. Thanks.
fatirishman53 is offline   Reply With Quote
Old   September 7, 2016, 10:24
Matt
As it turns out, our cluster administrator used a pre-compiled version of OpenFOAM for CentOS. In the end, the permissions ended up being more strict, which is why I was getting the premission errors (I know... duh). Also, the shared libraries weren't being written to $USER-$WM_PROJECT_VERSION. The admin ended up temporarily granting me full permissions over the OpenFOAM folder structure and I was able to get the problems sorted out.
I thought I had seen a solution where the shared libraries could be referenced from a global location, but I couldn't re-find it. If anyone knows about this, I would appreciate the information.
Thanks.
SAP cluster resource/services not coming online on cluster node 2 Nthar1@yahoo.com Hardware 0 May 9, 2017 05:55
[foam-extend.org] foam-extend 3.1 installation problems: ParaView 4.0.1 RPM won't install KayGhana OpenFOAM Installation 4 March 31, 2017 06:38
[OpenFOAM.org] Problems to install openfoam-2.4.0 on Ubuntu 16.04.01LTS matheusmonjon OpenFOAM Installation 3 February 25, 2017 14:46
error make SU2 4.0.1 Heathckliff SU2 Installation 2 November 9, 2015 05:48
How to install OpenFoam1.71 on cluster without Root permission? ripperjack OpenFOAM Installation 7 May 7, 2013 16:46
