Write cells and data intersecting a plane cuttingPlane
Like Tree5Likes
Old   January 28, 2008, 10:57
Default Hi, I would like to save durin
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
Hi, I would like to save during the run time, data (and cells) that intersect a plane. I saw the cuttingPlane class, but is there a code snippet on the web showing how to save those cells in a top level solver?
I want later on to be able to read those files with paraFoam or paraview.
Dragos
dmoroian is offline   Reply With Quote
Old   January 28, 2008, 11:48
Default Hi Dragos, yes, check this th
ville vuorinen
ville is on a distinguished road
Hi Dragos,
yes, check this thread. In case you need further
advice please continue the thread and I'll help
you. The cutting plane is very practical if you
like to take your data to matlab, gnuplot etc for
further analysis.
http://www.cfd-online.com/OpenFOAM_D...tml?1197913395
best regards,
Ville
Pagoda likes this.
ville is offline   Reply With Quote
Old   January 29, 2008, 02:14
Default Hi Ville, Actually your answe
dmoroian's Avatar
Dragos
Hi Ville,
Actually your answer was the source of my information in the first place. There you show how to access the cells and data, but I am interested in saving them in openfoam format. Can you show me how to do that?
If you help me, I promise to put toghether a wiki page so other people would benefit from it.
Dragos
Old   January 29, 2008, 04:41
Default Hi, unfortunately I doubt if
ville vuorinen
unfortunately I doubt if that is possible since
the cutting plane option is needed to extract data from the mesh so that connectivity information (which the post processor should need) is lost..
-Ville
Old   January 29, 2008, 04:57
Default Get the cells from the cutting
Mattijs Janssens
Get the cells from the cutting plane and construct a cellSet from them. Something like
const labelList& cutCells = cutPlane.cells();
cellSet someCells(mesh, "someCells", cutCells);
someCells.write();
Then use foamToVTK with -cellSet option.
mm.abdollahzadeh likes this.
Old   January 29, 2008, 14:58
Default Thanks both of you! This is w
dmoroian's Avatar
Dragos
Thanks both of you!
This is what I was after.
Old   January 30, 2008, 01:40
Default ...me again. The following co
dmoroian's Avatar
Dragos
...me again.
The following code works very well:
point pnt(0.5,0.25,-0.25);
vector direction(1,0,0);
plane pl1(pnt,direction);
cuttingPlane cutPlane(mesh,pl1);
someCells.write();
Here is a slice obtained with it:
... but I would like more. Is it possible to save together with the above cell set also the data associated to it at a certain time?
Dragos
Old   January 30, 2008, 10:17
Default Hi Dragos Thanks for the co
jaswi is on a distinguished road
Hi Dragos
Thanks for the code.
Could you also please post the list of include files so that this code compiles successfully. I put the code in my post processing routine exactly as you have psoted
point pnt(0.0,0.0,0.04);
someCells.write();
and get the following error:
postProcessing.C:654: error: 'plane' was not declared in this scope
postProcessing.C:654: error: expected `;' before 'pl1'
postProcessing.C:655: error: 'cuttingPlane' was not declared in this scope
postProcessing.C:655: error: expected `;' before 'cutPlane'
postProcessing.C:656: error: 'cutPlane' was not declared in this scope
postProcessing.C:657: error: 'cellSet' was not declared in this scope
postProcessing.C:657: error: expected `;' before 'someCells'
postProcessing.C:658: error: 'someCells' was not declared in this scope
postProcessing.C:656: warning: unused variable 'cutCells'
The list of files I have already included are:
#include "fvCFD.H"
#include "wallFvPatch.H"
#include "interfaceProperties.H"
#include "twoPhaseMixture.H"
#include "incompressible/turbulenceModel/turbulenceModel.H"
#include "nearWallDist.H"
#include "fixedValuePointPatchFields.H"
Thanks alot
With Kind Regards
Jaswinder
jaswi is offline   Reply With Quote
Old   January 30, 2008, 10:37
Default Hi Dragos I just checked o
Hi Dragos
I just checked out the cuttingPlane code and it has a member function called
//- Sample the cell field
template<class>
tmp<field<type> > sample(const Field<type>&) const;
It seems that if you add the following to your code snippet
volScalarField slicedDesiredField = cutPlane.sample(desiredField);
someCells.write();
You might be able to extract the field you want.
I could not test whether if it works as i am unable to compile the original code offered by you.
With Kind Regards
Jaswinder
Old   January 30, 2008, 11:51
Default Hi Dragos I have solved the
Hi Dragos
I have solved the compilation problem but now I have problem visualizing it.
I give the following command:
foamToVTK <root> <case> -cellSet someCells
and it writes
Exec : foamToVTK . 7_flask_10ml_320rpm -cellSet someCells
Date : Jan 30 2008
Time : 17:48:12
Host : taifun
PID : 5343
Root : <root>
Case : <case>
Nprocs : 1
Create time
Number of cells in new mesh : 6034
Number of faces in new mesh : 24264
Number of points in new mesh: 12342
--> FOAM FATAL IO ERROR : cannot open file
file: /scratch1/power_consumption_sims/1st_10ml/7_flask_10ml_320rpm/system/subsetSubse t/fvSchemes at line 0.
From function regIOobject::readStream(const word&)
in file db/regIOobject/regIOobjectRead.C at line 66.
FOAM exiting
Could you please give me a clue what is missing
With kind Regards
Jaswinder
Old   January 30, 2008, 15:42
Default Hi Jaswinder, Thanks for the
  #11
dmoroian's Avatar
Dragos
Hi Jaswinder,
Thanks for the information, I'll definitely try it (I have to check if volScalarField class can write down the data). On the other hand I have no idea why you get that error.
Dragos
Old   January 30, 2008, 16:09
Default foamToVTK .. cavity -cellSet c
  #12
Mattijs Janssens
foamToVTK .. cavity -cellSet c0
works for me (1.4.1):
Time constant
Internal : "../cavity/VTK/c0_0.vtk"
Original cells:5 points:24 Additional cells:0 additional points:0
Patch : "../cavity/VTK/movingWall/c0_0.vtk"
Patch : "../cavity/VTK/fixedWalls/c0_0.vtk"
Patch : "../cavity/VTK/frontAndBack/c0_0.vtk"
Patch : "../cavity/VTK/oldInternalFaces/c0_0.vtk"
Old   January 31, 2008, 01:46
Default Hi Mattijs, Will you give me
  #13
dmoroian's Avatar
Dragos
Hi Mattijs,
Will you give me a clue on how to get only the slice (both geometry and data)? I don't want to save the entire domain and then to get the slice.
Dragos
Old   January 31, 2008, 05:04
Default pull out the bits of code from
  #14
Mattijs Janssens
pull out the bits of code from subsetMesh. It takes a cellSet and creates a whole new fvMesh from it and subsets the cells as well.
Old   February 1, 2008, 10:40
Default Ok, new questions... In the s
  #15
dmoroian's Avatar
Dragos
In the subsetMesh utility the following lines read the mesh and the volume scalars from a specific time directory:
IOobjectList objects(mesh, runTime.timeName());
wordList scalarNames(objects.names(volScalarField::typeName ));
PtrList<volscalarfield> scalarFlds(scalarNames.size());
then a subset of it is constructed by
subsetVolFields(subsetter, scalarNames, scalarFlds);
Now my question is: how do I construct the subset from the variables I have in memory (during the calculation) and not read them from a dictionary?
Dragos
Old   February 5, 2008, 05:41
Default wiki: TurbPlaneCutFoam
  #16
dmoroian's Avatar
Dragos
manuc likes this.
Old   February 5, 2008, 05:59
Default Hmm, I need an idea: how to ma
  #17
dmoroian's Avatar
Dragos
Hmm, I need an idea: how to make it run in parallel?
Anybody can give me a clue?
This is the log file with the error I get when I run the solver in parallel:
channel_par.log
Dragos
Old   February 6, 2008, 09:25
Default Hello again, Running in paral
  #18
dmoroian's Avatar
Dragos
Hello again,
Running in parallel and getting the slices saved, seems to be ok. But how should I reconstruct the plane back from each processor? For instance, two processors will give me two pieces like in the following image:
How should I put them together?
reconstructPar doesn't seem to work for the cells saved from the cuttingPlane.
I can merge the mesh using mergeMeshes, but how can I merge the data?
Dragos
Old   February 26, 2008, 13:06
Default Hi Dragos, I tried your cod
  #19
Fabian Braennstroem
braennstroem is on a distinguished road
Hi Dragos,
I tried your code snip, but have some problems compiling it:
-lincompressibleLESmodels -lincompressibleTransportModels -lfiniteVolume -lmeshTools -lOpenFOAM -liberty -ldl -lm -o /home/gcae504/OpenFOAM/gcae504-1.4.1/applications/bin/linux64GccDPOpt/no_avg_ood les
Make/linux64GccDPOpt/no_avg_oodles.o(.text+0x31b5): In function `main':
: undefined reference to `Foam::cuttingPlane::cuttingPlane(Foam::primitiveM esh const&, Foam::plane const&)'
Make/linux64GccDPOpt/no_avg_oodles.o(.text+0x31c2): In function `main':
: undefined reference to `Foam::cuttingPlane::cells() const'
collect2: ld returned 1 exit status
make: *** [/home/gcae504/OpenFOAM/gcae504-1.4.1/applications/bin/linux64GccDPOpt/no_avg_oo dles] Error 1
I added these libraries to the oodles solver:
#include "plane.H"
#include "cuttingPlane.H"
#include "cellSet.H"
#include "fvMeshSubset.H"
Would be nice, if you have a hint, how to compile it!?
Regards!
Fabian
braennstroem is offline   Reply With Quote
Old   February 27, 2008, 05:09
Default Hi Fabian, It seems that you
  #20
dmoroian's Avatar
Dragos
Hi Fabian,
It seems that you have all the correct "#include" directives, since the error is from the link stage and not from compilation. What you basically need is the "-lsampling" option. Here is how my options file looks like:
EXE_INC = \
-I$(LIB_SRC)/LESmodels \
-I$(LIB_SRC)/LESmodels/LESdeltas/lnInclude \
-I$(LIB_SRC)/transportModels \
-I$(LIB_SRC)/finiteVolume/lnInclude \
-I$(LIB_SRC)/meshTools/lnInclude \
-I$(LIB_SRC)/sampling/lnInclude
EXE_LIBS = \
-lincompressibleLESmodels \
-lincompressibleTransportModels \
-lfiniteVolume \
-lmeshTools \
-lsampling
UDF to write a data file lichun Dong FLUENT 2 August 4, 2005 11:21
write transient data of plane Fabian CFX 2 June 27, 2005 02:38
UDF TO WRITE OUT DATA!! Aishwarya FLUENT 1 August 14, 2004 10:32
UDF TO WRITE OUT DATA!! Aishwarya FLUENT 0 August 12, 2004 10:11
UDF to read and write data Mcgregor FLUENT 4 June 9, 2003 13:21
