November 6, 2008, 11:03 |
Dear all,
I run a damBreakWit
nicasch
Dear all,
I run a damBreakWithObstacle tutorial with automatic mesh refinement. I was able to run it in parallel. During the first run I stopped it after a while and could not reconstruct the case. I obtained the following message: ... Create time Create mesh for time = 0 Time = 0 Reconstructing FV fields Reconstructing volScalarFields pd gamma gamma.org Reconstructing volVectorFields U No point fields No lagrangian fields Time = 0.00815822 cannot open file file: /home/eberberovic/OpenFOAM/eberberovic-1.5/run/damBreakWithObstacle/processor0/0 .00815822/polyMesh/pointProcAddressing at line 0. From function regIOobject::readStream(const word&) in file db/regIOobject/regIOobjectRead.C at line 66. FOAM exiting Then I run the case again until the end time. Running was OK. But reconstruction did not work, I obtained the same error as before. Any idea why this happens? Thanks and regards. |
November 7, 2008, 04:06 |
Your mesh has changed. So you
Mattijs Janssens
Rep Power: 26 |
Your mesh has changed. So you cannot just reconstruct the fields onto the original mesh (which is what reconstructPar does). Have a search for 'reconstructParMesh' on this forum.
Bug in reconstructPar | david | OpenFOAM Bugs | 10 | May 26, 2009 12:11 |
ReconstructPar | kupiainen | OpenFOAM Post-Processing | 12 | April 21, 2009 01:47 |
ReconstructPar | maka | OpenFOAM Bugs | 6 | August 22, 2007 04:23 |
Modified reconstructPar | jens_klostermann | OpenFOAM Post-Processing | 1 | March 29, 2007 14:34 |
ReconstructPar error | r2d2 | OpenFOAM Pre-Processing | 7 | September 12, 2006 09:37 |
