November 30, 2018, 06:12 |
pressure drop using chtMultiRegionFoam
Arthur
Rep Power: 7 |
I am trying to get the pressure drop between 2 different patches (inlet and outlet). In my controlDict I have included "#includeFunc patchAverage", and I have tried to use the postProcess -func patchAverage tool, however it tells me that I don't have a pressure field. Code:
Reading fields: Executing functionObjects surfaceFieldValue patchAverage write: --> FOAM Warning : From function virtual bool Foam::functionObjects::fieldValues::surfaceFieldValue::write() in file fieldValues/surfaceFieldValue/surfaceFieldValue.C at line 807 Requested field p not found in database and not processed Time = 39.75 I am using OpenFOAM 6, and I am unsure why it is not working. Is there a way to do this for specific patches within paraView instead of just OF? Can anyone help? Any help is appreciated! Thank you, Arthur Last edited by amdk136; November 30, 2018 at 06:22. Reason: adding info |
December 2, 2018, 14:29 |
anonymous
Rep Power: 14 |
Hi!
In chtMultiRegionFoam you have regions. So you have to add the "-region regionName" switch to your command, where regionName is the name of the region where you have that patch. |
December 3, 2018, 10:22 |
#3 | |
Arthur
Rep Power: 7 |
thank you for your reply! I have also tried with the "-region <region>", but when i do that I don't get a data file generated. After I posted this I tried just about every possible combination I could to no avail haha. I'll assume it's a deeper rooted problem. Thanks for the help though! Arthur |
December 3, 2018, 10:38 |
anonymous
Rep Power: 14 |
Ooo sorry. Maybe I know your problem.
You just ran "postProcess -func patchAverage", right? Try with "chtMultiRegionSimpleFoam -postProcess -func patchAverage -region <regionName>", or you can use directly like: chtMultiRegionSimpleFoam -postProcess -func "patchAverage(name=<patchName>, p)" -region <regionName> I've just tried. This is working perfectly for me: chtMultiRegionSimpleFoam -postProcess -func "patchAverage(name=inlet, p)" -region fluid -latestTime |
December 4, 2018, 08:01 |
Arthur
Rep Power: 7 |
Simrego,
Thank you again for your reply! I have tried that exactly how you have stated it, including the 'chtMultiRegionFoam' & also the 'region <region>' [as well as both with the "(name=patchName, field)" and without too], however no field data file is being created still. Seems to be a very odd situation. I don't even get a post processing folder when I include the 'chtMultiRegionFoam' part. Would it be possible for you to upload your case directory, please? So that I can see how you have it organised etc. And to see what I'm missing! (I understand if you'd rather not as well) Thank you again, Arthur |
December 4, 2018, 15:41 |
anonymous
Rep Power: 14 |
Sorry, I can't share that case with you, but you can try it on any tutorial case. If it's not working I think the problem will be in your OF.
Maybe you are using an old version with a bug? Or had you any problems during the compilation? Or just a typo in the command? Or try with a different function, ie. patchIntegrate (just for a try). |
December 5, 2018, 07:09 |
#7 | |
Arthur
Rep Power: 7 |
Simrego, I have just run my case again and used the command you gave above (adapted for my case): Code:
chtMultiRegionFoam -postProcess -func "patchAverage(name=cyclicFluidInlet, p_rgh)" -region water -latestTime I was running the postProcess tool without "-latestTime" which was my problem as I didn't notice it on my phone. Posting again incase anyone else has the same problem as me Thank you very much for your help again, Arthur |
Display Modes | |
Fluent cyclone pressure drop | mkal | FLUENT | 1 | February 20, 2020 01:55 |
How to plot pressure drop with Periodic BC? | bigfans | FLUENT | 7 | November 8, 2016 12:28 |
Pressure drop using Fan type BC | Alexis Sack | OpenFOAM Running, Solving & CFD | 2 | September 22, 2014 10:18 |
How to study pressure drop of continous phase in VOF model | sajeesh | FLUENT | 4 | February 5, 2014 23:01 |
Pipe Flow - Pressure Drop | Daniel L | FLOW-3D | 2 | December 10, 2010 05:23 |
