-   OpenFOAM Post-Processing (http://www.cfd-online.com/Forums/openfoam-post-processing/)
-   -   Calculation for a given plane possible in OpenFOAM (http://www.cfd-online.com/Forums/openfoam-post-processing/61358-calculation-given-plane-possible-openfoam.html)
santos February 25, 2007 21:07
Hello! I know that it is po
Hello!
I know that it is possible to calculate a given field on a boundary, such as:
label inletPatchi = mesh.boundaryMesh().findPatchID(nameOfInlet);
scalar massFlux = sum(phi.boundaryField()[inletPatchi]);
It is also possible to get the field value of an arbitrary point as:
vector probePoint(x,y,z);
label probeCell = mesh.findCell(probePoint);
But is it possible to get the values of a field for a given plane? I need to get field values only for y=0.002. Any hint on how to do this in OpenFOAM?
Thank you!
Best regards,
Josť Santos
dmoroian February 26, 2007 03:35
Hi Jose, Maybe sampleSurface
Hi Jose,
Maybe sampleSurface is what you want!
Dragos
santos February 26, 2007 05:12
Hi Dragos Thanks for your r
Hi Dragos
Thanks for your reply.
Yes sampleSurface works, in fact I am using it now to export the values to Octave to do the calculations I need. But I think it would be better if I could do it all in OpenFOAM!
Josť Santos
ville October 3, 2007 05:49
Hi, I would be interested in
I would be interested in using the sampleSurface
utility for sampling cutplanes to a directory during a simulation so that I would not have to save all the 3D data and sample the cutplanes as a postprocessing task since the 3D files take a lot of space. Is this readily possible?
Thanks in advance!
Ville
eugene October 3, 2007 09:51
It is possible, but not readil
It is possible, but not readily.
ville October 3, 2007 10:11
Thank you for the reply! Wha
What steps would be required to use the
related sampling dictionary
every dt intervals; would there be any possible piece of code for doing that? It would be quite
wonderful to try out since visualizing transient
phenomena in a time-resolved way becomes very
time consuming
if the animations are made out of large 3d data
sets.
-Ville
P.S. Since I couldn't find this on the forum:
An example of using the sampleSurface as a postprocessing tool is found in
~/OpenFOAM/OpenFOAM-1.4.1/tutorials/
solidDisplacementFoam/plateHole/system
eugene October 3, 2007 10:21
You would have to integrate th
You would have to integrate the sampleSurface utility into an application, or for more general use, into a function object. A fair amount of work unfortunately and I am not aware of existing applications that perform this task.
maka February 26, 2008 13:21
will it work in parallel if we
will it work in parallel if we did so? If so I can try to do it since, I've been looking for a way to average fields in a set of planes during parallel run and this can do it if the sampling period is long enough to not to make the code slow.
eugene February 27, 2008 05:32
sampleSurface works in paralle
sampleSurface works in parallel.
dmoroian February 27, 2008 06:15
Saving a cell set that interse
Saving a cell set that intersects a plane at runtime is presented here: cuttingPlane
It works in parallel, too.
Dragos
lakeat October 10, 2008 04:00
Hi, Since OpenFOAM already
Since OpenFOAM already includes many third party software, why not add another one, say octave?
I am thinking these days, is it possible to do FFT with OpenFOAM? Because FFT utility is very common and very useful and ver important for post-processing, why not it is included?
It would be nice to see post-processing has the ability of Graphic showing and spectrum analysis etc.
Just a thought. \Daniel
Pascal_doran June 4, 2010 13:59
Hi Daniel,
It seem that OpenFOAM 1.6 has FFT utility. See /usr/local/OpenFOAM/OpenFOAM-1.6/src/randomProcesses/fft
And I was wondering if you were able to use it. If yes could you show me how?
Thank you,
Pascal
Bertrand December 2, 2010 16:47
I would be interested in this use as well, if anyone has information on how to implement a FFT on OpenFOAM probes.
Thanks!
mani_v January 9, 2011 22:12
Originally Posted by santos (Post 197456)
Hello!
Thank you!
Best regards,
Josť Santos
Jose
I am new to openfoam. Can you tell where these lines can be added to calculate massflux at a boundary? It will be very helpful if you can show me an example.
CedricVH August 5, 2011 06:09
Originally Posted by mani_v (Post 289790)
Jose
You can better calculate the massflux through a boundary through a functionObject. Add this to your controlDict file to calculate the massflow through the inlet at write time.
functions
    mflow_inlet
        type            faceSource;
        functionObjectLibs ("libfieldFunctionObjects.so");
        enabled        true;
        outputControl  outputTime;
        log            true;
        valueOutput    true;
        source          patch;
        sourceName      inlet;
        operation      sum;
        fields
            phi
You can also achieve the same by post-processing the data using the command:
patchIntegrate -latestTime phi inlet
