Home > Forums > OpenFOAM Post-Processing
TecPlot 9 for MS windows
Old   March 14, 2005, 09:35
Default Hi, I have TecPlot version
Pei-Ying Hsieh
hsieh is on a distinguished road
I have TecPlot version 9 for MS windows. Is it possible to export data (transient problems) so that they can be read by TecPlot 9 on MS Windows?
Thanks!
Pei
hsieh is offline   Reply With Quote
Old   March 14, 2005, 20:20
Default Convert the result data into f
kim
Hyung min Kim
kim is on a distinguished road
Convert the result data into fluent data format
then, you can import the data by tecplot.
kim is offline   Reply With Quote
Old   March 16, 2005, 11:48
Default Hi Guys I did convert the f
Wladimyr Mattos da Costa Dourado
mattos is on a distinguished road
Hi Guys
I did convert the foam data to fluent using foamDataToFluent but it converts only the field of time = 0. What I must to do in order to convert the others times which are stored into their respectives directories?
Tanks!
Wladimyr
mattos is offline   Reply With Quote
Old   March 16, 2005, 11:56
Default foamDataToFluent is currently
henry is on a distinguished road
foamDataToFluent is currently setup to convert the time you specify as startTime in controlDict. Try setting startTime to latestTime.
henry is offline   Reply With Quote
Old   March 16, 2005, 13:22
Default I converted both mesh and data
ali
Ali Heidari
ali is on a distinguished road
I converted both mesh and data from Foam for Fluent. When I wanted to import only the mesh (no data) it into Tecplot ver. 10, there was an error:
"Error reading section number in file"
When I pressed "ok", Tecplot brought the mesh. But when I tried to import both mesh and data into Tecplot, I got the same error:
After pressing, "OK", another error popped up:
"ZoneID 1 referenced in data file is a node zone".
and when I clicked "OK", it DIDN'T even load the mesh itself. Seems it's not possible to see the
Anybody, has experienced similar thing?
ali is offline   Reply With Quote
Old   April 7, 2005, 20:31
Default I have the same question as Al
Luckyluke
luckyluke is on a distinguished road
I have the same question as Ali.
luckyluke is offline   Reply With Quote
Old   August 28, 2008, 10:11
Default I too am getting the same prob
Gemma Coughlin
gemma is on a distinguished road
I too am getting the same problem as Ali, using tecplot 360 does anyone have any ideas how to fix this?
Cheers
Gemma
gemma is offline   Reply With Quote
Old   September 2, 2008, 15:00
Default Below is a copy of my Post.sh
Dennis Kingsley
dkingsley is on a distinguished road
Below is a copy of my Post.sh script that I use with Tecplot 360 and OF1.5. If you don't have preplot on your OF machine just comment it out. The foamToTecplot was posted in one of the forum messages for 1.4.1-dev, I had no problem compiling it under 1.5.
the first parameter is the case and the second is the time step to extract.
#!/bin/sh
reconstructPar -case $1 -time $2
foamToTecplot -case $1 -time $2
preplot ./$1/TecplotData/$2.dat
gzip ./$1/TecplotData/$2.plt
rm ./$1/TecplotData/$2.dat
dkingsley is offline   Reply With Quote
Thread Tools
Trackbacks are On
How to read tecplot file witout tecplot ? Pol Tecplot 11 March 2, 2007 07:26
