Home > Forums > OpenFOAM Post-Processing
Check mass continuity
Old   March 22, 2006, 06:42
Default Hi! Is there an easy way to
Andreas Hauffe
andimb is on a distinguished road
Hi!
Is there an easy way to check the mass continuity (incompressible) at the Inlet compared to the Outlet? I never wrote something in C++, so it would be hard to write some code. I'm just used to FORTRAN and Java.
If there's now easy way I could use the liftDrag tool as example, right? This is quit near to this.
The mass continuity for an incompressible flow is defined as div U = 0. Could I use that for a check.
Andreas
andimb is offline   Reply With Quote
Old   March 22, 2006, 09:11
Default Hi! I found the button in p
Andreas Hauffe
Hi!
I found the button in paraView to integrate over surfaces. So it is ok
Thanks
Andreas
Old   March 23, 2006, 07:39
Default Write a little code and do a s
Hrvoje Jasak
Write a little code and do a sum of the fluxes, e.g.
sum(phi.boundaryField()[outletPatchIndex])
Remember, the flux going out is positive and the one going in is negative.
The local and global continuity data also gets reported during the run - have a look at your log file or the implementation. For incompressible flows src/cfdTools/incompressible/continuityErrs.H does the sum over all cells:
scalar sumLocalContErr = runTime.deltaT().value()*
mag(fvc::div(phi))().weightedAverage(mesh.V()).val ue();
scalar globalContErr = runTime.deltaT().value()*
fvc::div(phi)().weightedAverage(mesh.V()).value();
cumulativeContErr += globalContErr;
Info<< "time step continuity errors : sum local = " << sumLocalContErr
<< ", global = " << globalContErr
<< ", cumulative = " << cumulativeContErr
<< endl;
Enjoy,
Hrv
Hrvoje Jasak
Old   April 13, 2006, 11:20
Default Hi, I have calculate a tuto
tak
taka
tak is on a distinguished road
I have calculate a tutorial case "pitzDaily" with transports of chmical species (H2,O2,N2....) by means of reactingFoam (no reaction).
Could you please teach me how to calculate the material balances of chemical species ?
Now, I can calculate mass flow rates at the inlet and outlet like this:
label inletPatchi = mesh.boundaryMesh().findPatchID("inlet");
scalar inFlux = sum(phi.boundaryField()[inletPatchi]);
But I can't calculate mass flow rates of chemical species at the inlet and outlet.
Thanking you in advance for your help,
taka
tak is offline   Reply With Quote
Old   April 14, 2006, 03:02
Default Sorry, it's so easy to calcula
tak
taka
Sorry, it's so easy to calculate mass flow rate of chemical specie Y[i] at an inlet.
scalar inFlux =
* sum(rho.boundaryField()[inletPatchi]
* Y[i];
Thanks.
Old   June 4, 2008, 05:28
Default Hi all, i can see that phi(fl
davey david
suredross is on a distinguished road
Hi all,
i can see that phi(flux)is calculated for each time step and has entries for each cell.now comes the question:how does one verify that mass continuity and or conservation is achieved?is it by looking at the entries in the phi file and making sure that they are the same,taking into account the + and - signs correspond to outlet and inlet values?or am i totally wrong?
thanks for the help.
cheers
davey
suredross is offline   Reply With Quote
Thread Tools
Trackbacks are On
How to check Heat Balance in heat transfer like mass balance for flow mahendra OpenFOAM Post-Processing 15 February 8, 2012 11:19
How to check Y value sivakumar OpenFOAM Pre-Processing 3 October 6, 2008 14:59
Please check this UDF. Josh FLUENT 0 February 8, 2006 12:27
Check this UDF,please. Josh FLUENT 2 February 2, 2006 15:02
Cell check and Boundary check errors AB CD-adapco 4 October 28, 2004 13:04
