-   OpenFOAM Post-Processing (http://www.cfd-online.com/Forums/openfoam-post-processing/)
-   -   Postprocessing with AVSExpress (http://www.cfd-online.com/Forums/openfoam-post-processing/61390-postprocessing-avsexpress.html)
cedric_duprat May 15, 2008 12:38
Hello, I plan to postproce
I plan to postprocess my data from OpenFOAM with AVS/Express.
I found on the opencfd website that it is possible :
http://www.opencfd.co.uk/openfoam/in...PostProcessing
Then, I looked for something like FoamToAVS, without any success.
Even in the sourceforge web site, there is nothing for AVS/express.
Does anybody know how is called the data converters from OpenFOAM to AVS, maybe it is not so straightforward ?
Or it might be a mistake in the opencfd web site ?
Any ideas, how I can do that please ?
Regards,
Cedric
cedric_duprat May 16, 2008 11:56
Hello again, I tried to use
Hello again,
I tried to use the foamToFieldview9 which create a *.uns files. It's a Fieldview-UNS format (binary) file with both mesh and field but, there is no way to read it in AVS.
Then, I found that a VTK reader is avaiable on AVS. But FoamToVTK create binaries files which are not usefull in AVS.
Maybe someone has more ideas, cause I haven't got any more yet ?
Cedric
alexandrepereira May 16, 2008 14:04
I guess that the format FoamTo
I guess that the format FoamToVTK uses is not the most correct ... when i try to create foamToVTK . myTestCase -ascii, the output is not binary... nevertheless, mayaVi, a vtk reader, cannot access the CFD data, nor can VisIt...
Anyway paraFoam . myTestCase successfully displays all the CFD quantities in myTestCase...
Alex
cedric_duprat May 19, 2008 07:30
Thank you Alexandre for your a
Thank you Alexandre for your answer.
You're right, with the -ascii option it's better but, it's still not working, AVS "can't read the number of Cells".
Anyway, I will work first with paraFoam which is working fine for me also.
Cedric
