-   OpenFOAM Post-Processing (http://www.cfd-online.com/Forums/openfoam-post-processing/)
-   -   FoamToVTK Animation with Paraview 3 (http://www.cfd-online.com/Forums/openfoam-post-processing/61425-foamtovtk-animation-paraview-3-a.html)
podallaire October 5, 2007 09:52
Good morning guys, I've bee
Good morning guys,
I've been using paraview 3 and paraview 2-6 for the last two weeks to check my OpenFOAM results. In order to visualize my results with Paraview 3 (paraFoam will not work), I used the foamToVTK converter (which works very well) and opened the VTK files with Paraview 3. The only thing is that I'm not able to get an animation in Paraview 3 with all my time steps. Any idea on how to do it ? All time steps where converted with foamToVTK.
Best regards,
PODallaire
gschaider October 7, 2007 15:27
Animations didn't work with 3.
Animations didn't work with 3.0 AFAIK. I don't know if 3.1 or 3.2 is the first version to support that
7islands October 7, 2007 19:00
Hi Pierre-Olivier, There's an
Hi Pierre-Olivier,
There's an entry on ParaView Wiki.
http://paraview.org/Wiki/Animating_l...TK_file_series
Looking around the source tree it seems the latest CVS seems to have this feature built-in (I haven't tested it myself though)
Takuya
podallaire October 8, 2007 07:47
Bernhard and Takuya, thanks
thanks for messages. I'll take a look on the paraview wiki
as suggested by Takua.
PO
podallaire October 9, 2007 00:26
Hi, as mentionned on the wi
as mentionned on the wiki, Paraview as a "multi-file" reader
for VTK legacy files. I tried it but even if it looks that it is opening
a group of files, it seems that only one random file will open.
Did you try it Takuya ?
Thanks
PO
7islands October 9, 2007 07:26
Hi, Yes it worked with today'
Yes it worked with today's CVS version. Note that you need to select group name on the right of disclosure mark (the blue highlighted "blow..vtk" in the Wiki case), not individual timestep files.
Takuya
