July 6, 2007, 08:45 |
Hi to all,
I am simulating
hadi tartoussi
Rep Power: 17 |
Hi to all,
I am simulating a LES turbulent channelflow using channelOodles, i fixed the value of Ubar and i ran the case for few iterations, i would like to get the values of u_tau in order to estimate the corresponding Re_tau. Does openFoam print out these values? u_tau=(nu*(du_x/dy+du_z/dy))^0.5 Thanks in advance hadi |
July 6, 2007, 08:49 |
please Hady try not to make a
Maka Mohu
Rep Power: 18 |
please Hady try not to make a new thread for every new question you have. In this way, you make your chances to get answer lower and also make it harder for others to follow the topics. There are several posts on channelOodles. Post on one of them your question.
Have a nice day, Maka |
July 6, 2007, 09:27 |
Sorry Maka, you are right,but
hadi tartoussi
Rep Power: 17 |
Sorry Maka, you are right,but i thought that old threads are closed.
Cheers Hadi |
July 6, 2007, 09:51 |
On the contrary some users get
Maka Mohu
Rep Power: 18 |
On the contrary some users gets an email alert (check Edit Profile) when one of the the threads that they used has a new question. As a result, your chance is higher to get an answer for a question if you managed to find a thread that "related to it". The last part is important otherwise, your message may be ignored. It is OK, I have done the same when I started. I just learned that by trial and error :-). Good luck with your computations. Have a nice day!
Best regards, Maka |
July 9, 2007, 04:35 |
Thanks Maka for your advice, i
hadi tartoussi
Rep Power: 17 |
Thanks Maka for your advice, i will repost my message in an old thread
Cheers Hadi |
Display Modes | |
results for flow past flat plate normal to flow | lisa | Main CFD Forum | 2 | August 30, 2005 17:36 |
External Flow-compressible flow solver-lift/drag | Tom Brown | Main CFD Forum | 7 | December 29, 2000 14:41 |
