Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Modified reconstructPar
Old   March 29, 2007, 12:21
Default Hi, I hope one day there is
Jens Klostermann
jens_klostermann is on a distinguished road
I hope one day there is no need to use this utility anymore and I can read the decomposed mesh in paraFoam/paraview directly. I read something about this will be possible with OF1.4?
But for now I have to use reconstructPar. I had problems reconstructing large cases fast, especially if there are many time steps, since it is not possible to reconstruct in parallel. So I changed the reconstructPar so that it is possible to use more than one reconstructPar at the same time. For this I added an option -reconStartTime, which is the first time step I want to reconstruct and -reconTimeStepFactor, which is the factor for nth time step to reconstruct.
Example: -reconStartTime=0.02 and -reconTimeStepFactor=3 the time steps 0.02 0.06 0.09 0.12 etc will be reconstructed.
And with (put it in a script):
reconstructParNew <root> <case> -reconTimeStepFactor 3 -reconStartTime 0.02 > reconstructlog1 &
reconstructParNew <root> <case> -reconTimeStepFactor 3 -reconStartTime 0.03 > reconstructlog2 &
reconstructParNew <root> <case> -reconTimeStepFactor 3 -reconStartTime 0.04 > reconstructlog3 &
I can reconstruct "parallel" at least distribute it easy. But watch for the main memory (swapping)!
I added also the -delete option so that the last reconstructed time will be delete automatic in the processor directory. See also http://www.cfd-online.com/OpenFOAM_Discus/messages/1/1547.html and http://www.cfd-online.com/OpenFOAM_D...es/1/1536.html
reconstructParNew.tar.gz
P.S. Maybe this is not the clean code it should be, but it does the job.
Regards Jens
jens_klostermann is offline   Reply With Quote
Old   March 29, 2007, 14:34
Default Hi, there is a little bug i
Jens Klostermann
there is a little bug in my example, it should go:
Example: If the solver dumps every 0.01 to the processor directories and -reconStartTime=0.02 and -reconTimeStepFactor=3 the time steps 0.02 0.05 0.08 0.11 etc. will be reconstructed. Sorry.
Jens
Bug in reconstructPar david OpenFOAM Bugs 10 May 26, 2009 12:11
ReconstructPar kupiainen OpenFOAM Post-Processing 12 April 21, 2009 01:47
ReconstructPar in OpenFOAM15 nicasch OpenFOAM Post-Processing 1 November 7, 2008 04:06
ReconstructPar maka OpenFOAM Bugs 6 August 22, 2007 04:23
Problem with reconstructPar fabianpk OpenFOAM 5 August 14, 2007 09:17
