Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
ReconstructPar channelOodles error
Old   November 25, 2005, 15:29
Default I'm running a parallel case on
Maka Mohu
maka is on a distinguished road
I'm running a parallel case on 2 processors with channelOodles (the standard case). I get this error when running reconstructPar on the case:
Create time
Create mesh
Time = 0
Reconstructing FV fields
Reconstructing volScalarFields
nuTilda
terminate called after throwing an instance of 'std::bad_cast'
what(): St8bad_cast
Aborted
Can any body help spot the problem. Thanks.
Maka
maka is offline   Reply With Quote
Old   November 25, 2005, 15:32
Default I think it is related to bound
Maka Mohu
I think it is related to boundary condtions, since reconstructPar works fin on cavity. I would be grateful if any body can give suggestions.
/Maka
Old   November 28, 2005, 03:35
Default Does any body face the same pr
Maka Mohu
Does any body face the same problem? Thanks.
Old   September 12, 2006, 09:14
Default I am having the same problem,
Daniele Panara
panara is on a distinguished road
I am having the same problem, could it be the cyclic BCs?
Daniele
panara is offline   Reply With Quote
Old   September 12, 2006, 17:41
Default Hello Daniele Are you using
santos's Avatar
Jose Luis Santos
santos is on a distinguished road
Send a message via Skype™ to santos
Hello Daniele
Are you using OpenFOAM 1.3? And in that case, are you using the last version of reconstructPar utility (check the bugs section of this forum)?
Regards
José Santos
santos is offline   Reply With Quote
Old   September 13, 2006, 02:00
Default Hi Jose', I am using OF 1.2
Daniele Panara
Hi Jose',
I am using OF 1.2, and I am not sure of using the last version of reconstructPar...
Where I can get an updated version? I am searching in the bug section of this forum but I cannot find anything related to reconstructPar...
At which trend you are referring to?
Daniele
Old   September 13, 2006, 16:16
Default Hello I dont remember where
santos's Avatar
Jose Luis Santos
Hello
I dont remember where I found it, but anyway try upgrading to OF 1.3, I think the problem is solved in the new version.
Regards
José Santos
Error in channelOodles tutorial alberto OpenFOAM Bugs 62 June 8, 2010 07:13
Bug in reconstructPar david OpenFOAM Bugs 10 May 26, 2009 12:11
[mesh manipulation] Error with reconstructPar skabilan OpenFOAM Meshing & Mesh Conversion 3 June 10, 2008 18:34
ReconstructPar error r2d2 OpenFOAM Pre-Processing 7 September 12, 2006 09:37
[OpenFOAM] Error while postprocessing channelOodles tutorial in OpenFOAM 13 alberto ParaView 4 April 13, 2006 05:58
