I was taking a look
I was taking a look at the calculation of y-plus with the checkYPlus utility, but isn't this in fact a check for y-star? Y-star = rho*Cmu^0.25*sqrt(k)*y/mu y-plus = rho*sqrt(tau_w/rho_w)*y/mu Thus Y-star is related to the turbulent kinetic energy and y-plus to the wallshearstress, or am I now overlooking something? kind regards Guido |
Hey Guido
I'm running some calculations with RSTMs and while checking y+ for the first cell I recognized the same. Checking via the yPlusRAS command creates totally different values than the calculation with: y+ = Utau*y/nu with Utau = SQRT(Tau_wall/rho) Meanwhile did you figured out something to avoid this curio? Thanks and regards, Sven |
although its old.but I have found that yPlusRAS uses y* furmula in return of y+.could anyone guide me or give an explanation on why?:)
Check out this post, Niklas has came up with a solution by modifying the file yPlusLES.C: http://www.cfd-online.com/Forums/ope...tml#post280296 best |
thanks Mojtaba.
but my case is compressible.do you know how to change the incompressible yPlus code? and also it doesn't compile in OF 2.2.0: Code:
ehsan@Ehsan-com:~/Desktop/yPlus$ wmake |
Which file did you use to compile? |
the second file he has put there.are they only for LES?
1 Attachment(s)
the uploaded file is the utility I used for incompressible flows using RAS models. |
it gives this error.maybe it should modified for 2.2.0 version.
There is no nutWallFunctionFvPatchScalarField.H inside yPlus.C that it can't find. instead nutkWallFunctionFvPatchScalarField.H is used. Are you sure you are using the file I uploaded? I don't know if it has changed in OF 2.2 or not. maybe its dependency issues. |
yes.I use that file.
can anyone help how change it to adapt to 2.2.0 version? |
in mutkWallFunctionFvPatchScalarField the equation uses for y-plus is related to y-star not y-plus
Code: Code:
y-star=pow(0.09,0.25)*sqr(k)*nearDist()/mu Code:
y-plus=rho*u_star*y/mu which u*=aqrt(taw_w/rho) in the code of mut : Code: Code:
forAll(mutw, faceI) { label faceCellI = patch().faceCells()[faceI]; scalar yPlus = Cmu25*y[faceI]*sqrt(k[faceCellI])/(muw[faceI]/rhow[faceI]); if (yPlus > yPlusLam_) { mutw[faceI] = muw[faceI]*(yPlus*kappa_/log(E_*yPlus) - 1); } } |
could anyone have a look to resolve the error?
Hi Mojtaba,
I used your yPlus utility. I ran a case using KKLOmega turbulence model with simpleFoam solver. I ran your yPlus utility after the simulation was completed. For every time step I am getting values of yPlus as "min=0, max=0, average=0". How to fix this? Also, the yPlusRAS utility that comes with OF-2.1.1 also has the problem of reporting y* instead of y+? Regards, Mayank |
My understanding of this issue is that the quantities of y-plus and y-star are approximately the same for equilibrium turbulent boundary layers. In equilibrium turbulent boundary layers, the friction velocity u_tau is approximately equal to Cmu^0.25*sqrt(k) in the log-law region, which is exactly the definition of u_star. However, in local non-equilibrium conditions such as separation and re-attachment, a deviation exists between u_tau and u_star, as u_tau is no longer approximately equal to Cmu^0.25*sqrt(k). I look forward to anyone correcting me if I am wrong here. |
As regards OpenFOAM , nutLowReWallFunctions/mutLowReWallFunctions calculates y-plus according to the wall shear stress and the friction velocity. Other wall functions for nut/mut, such as mutkWallFunction, calculates y-plus in the way of calculating y-star.
You can borrow the code for the calculation of y-plus in nutLowReWallFunctionFvPatchScalarField.C/mutLowReWallFunctionFvPatchScalarField.C to write your own utility or function object to calculate y-plus. |
Whether the utility calculates y+ or y* seems to depend on the OpenFOAM version you're using. The latest versions of both OpenFOAM and OpenFOAM+ seems to use the equation for y+. In older versions, it can be either y+, y* or depending on the turbulence model.
OpenFOAM 3.0.x: OpenFOAM-3.0.x/src/postProcessing/functionObjects/utilities/yPlus/yPlus.C in void Foam::yPlus::execute() Code:
const cmpModel& model = Code:
template<class TurbulenceModel> OpenFOAM-4.x/src/functionObjects/field/yPlus/yPlus.C in void Foam::functionObjects::yPlus::calcYPlus(turbModel, mesh, yPlus) OpenFOAM-dev/src/functionObjects/field/yPlus/yPlus.C in void Foam::functionObjects::yPlus::calcYPlus(turbModel, yPlus) Code:
yPlusBf[patchi] = src/functionObjects/field/yPlus/yPlus.C in bool Foam::functionObjects::yPlus::execute() Code:
yPlusBf[patchi] = |
