Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Running sampleSurface (interpolatedIsoSurface) of OF-1.4.1 on the solution of OF-1.5
Old   October 23, 2009, 09:40
Default Running sampleSurface (interpolatedIsoSurface) of OF-1.4.1 on the solution of OF-1.5
Suresh kumar Kannan
kumar is on a distinguished road
Hello ,
I want to run the SampleSurface utility of OF-1.4.1 for extracting IsoSurface from the solution files of OF-1.5. I have installed OF-1.4.1 specially on a 32bit machine for this purpose. My OF-1.5 cases are parallel computing results and then i reconstruct the results. But when i try to run the SampleSurface utility with the definition as given in some previous posts, it says the following error
#0 Foam::error:rintStack(Foam::Ostream&) addr2line failed
#1 Foam::sigSegv::sigSegvHandler(int) addr2line failed
#2 Uninterpreted: [0xb7f73420]
#3 Foam::List<Foam::cell>::List(int) addr2line failed
#4 Foam:rimitiveMesh::calcCells() const addr2line failed
#5 Foam:rimitiveMesh::cells() const addr2line failed
#6 Foam::Cloud<Foam:assiveParticle>::Cloud(Foam:o lyMesh const&, Foam::IDLList<Foam:assiveParticle> const&)
#7 Uninterpreted: sampleSurface [0x8068dc2]
#8 __libc_start_main addr2line failed
#9 Foam::regIOobject::readIfModified()
Segmentation fault
any suggestions to solve this problem.
bye
with regards
K.Suresh kumar
kumar is offline   Reply With Quote
Old   December 23, 2009, 15:30
Nikolaos Spyrou
nikos_fb16 is on a distinguished road
hello kumar,
i have the same problem you posted. did you find a way to sample the isosurface? please let me know. I'm looking for a way to do it with the 1.5 version but I havent found a solution yet.
nikos
nikos_fb16 is offline   Reply With Quote
Old   December 24, 2009, 05:21
Suresh kumar Kannan
Hello Nikos,
I was not able to run the sampleSurface utility for interpolated isosurface in OF-1.5. I think this utility does not work for extracting isosurface in OF-1.5.
And I was not able to use the samplesurface utility of OF-1.4.1 on the files of OF-1.5. I dont know the reason why this does not work.
So finally I made a new user account on my machine and Installed OF-1.6.x and then used the samplesurface utility of OF-1.6.x by just changing the filename to alpha1 on the files of OF-1.5.
Also installing OF-1.6.x was not a big deal thanks to the script available on the forum.
You can also extract the isosurface in Paraview by using the contour utility and specifying a value of 0.5.
bye
goodluck
with regards
K.Suresh kumar
Old   January 20, 2010, 19:33
Celestin Picasso Zemtsop
uwyomath is on a distinguished road
Hi Guys:
How do you use "sampleDict" to sample over a volume on OpenFOAM-1.5.
Regards, Celestin
uwyomath is offline   Reply With Quote
Old   January 22, 2010, 07:02
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
I think the reason that sampleSurf(1.4) doesn't work on a 1.5 case is because the mesh definition (amongst other things) is slightly different between the versions.
You could try changing the case mesh definition to be like 1.4 by following this post:
http://www.cfd-online.com/Forums/ope...m-1-4-1-a.html
But the results file are probably a different version too so I am not sure if it will work, but just an idea.
Philip
bigphil is offline   Reply With Quote
CFL Condition Matt Umbel Main CFD Forum 19 June 30, 2020 08:20
grid dependancy gueynard a. Main CFD Forum 19 June 27, 2014 21:22
Discussion about Mesh independant solution Seb Main CFD Forum 13 May 22, 2001 13:37
About the difference between steady and unsteady problems Lisa Main CFD Forum 11 July 5, 2000 14:37
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 01:16
