I'm solving a case with big nu
I'm solving a case with big number of nodes and I need to save the instantaneous data. I need to modify the reconstructPar to delete the reconstructed parallel directories (within the reconstruction loop). I need to add an option to the command -savestorage which let the reconstructPar delete the reconstructed directory after reconstructing it. This can not be done at the end since the data are near a terra bite. I would be gratefule if any body can help.
Best regards, Maka |
I checked util/parallel/recost
I checked util/parallel/recostructPar.C. I know where (end of time-directories loop) to put the delete statement but I can't figure out what should I write to delete the folder. Can any body help.
Regards, Maka |
Try
for(label np = 0; np <
Try
for(label np = 0; np < nProcs; np++) { rmDir(mesh.path()/fileName(word("processor")+Foam::name(np))); } or something similar. Foam wrappers for a lot of system commands can be found in Unix.C. |
