October 25, 2005, 14:47 |
I tried uniform, clouds, faces
diablo80@web.de
Rep Power: 17 |
I tried uniform, clouds, faces, and several lines (since there was a bug report about lines passing throught edges and points) but it did not work: the directory samples was created (and its subdirectory with the time name) but nothing was written...
Has anyone had the same problem? |
October 26, 2005, 13:41 |
Lots of times and usually the
Mattijs Janssens
Rep Power: 26 |
Lots of times and usually the line was not actually passing through the cells or there is something wrong with the mesh.
Use checkMesh to check your mesh dimensions and make sure the sampling line passes through. If 'uniform' sampling switch on the 'uniform' debug switch in the .OpenFOAM-1.2/controlDict. Does the sampling in the tutorial (icoFoam cavity case?) work? |
Display Modes | |
rasInterFoam Channel Flowlooking for working case | nico765 | OpenFOAM Running, Solving & CFD | 4 | March 24, 2009 00:49 |
Sample for DNS | mamaly60 | OpenFOAM Pre-Processing | 0 | October 25, 2007 09:46 |
sample UDF | Gang | FLUENT | 5 | March 4, 2003 02:34 |
Working with compressed case and data files | Darrell Anthony Egarr | FLUENT | 0 | December 15, 2002 07:05 |
for more sample cases? | bin xia | CFX | 6 | July 17, 2001 20:02 |
