May 23, 2005, 10:23 |
Hello everybody,
for the purp
Rolando Maier
Rep Power: 17 |
Hello everybody,
for the purpose of postprocessing I want to evaluate my CFD results on certain cuts of the flow domain. Is there any functionality implemented to cut a geometric field with a plane or even a number of faces (defining a cambered surface). Regards Rolando |
May 23, 2005, 10:43 |
Sure, see the "mapping" subdir
Eugene de Villiers
Rep Power: 21 |
Sure, see the "mapping" subdirectory of lesInterFoam for an example of a cutting plane. Be warned, it might have some issues with degenerate cuts.
May 23, 2005, 10:52 |
Thanks a lot Eugene.
Rolando Maier
Rep Power: 17 |
May 23, 2005, 10:53 |
There is functionality in Para
Rep Power: 22 |
There is functionality in ParaView to do this.
May 23, 2005, 11:11 |
http://www.opencfd.co.uk/openf
Chris Greenshields
Rep Power: 17 |
May 23, 2005, 11:29 |
Thanks Henry, thanks Chris,
I
Rolando Maier
Rep Power: 17 |
I want to do some calculations with the data on the cuts (e.g. averaging, averaging in one direction, integrating). Is this possible in ParaView, e.g. by using the Calculator-filter? If not, is it possible to write the data of the paraView-cuts and do further manipulation using the OpenFOAM library? Rolando |
May 23, 2005, 11:43 |
To find out what is possible i
Rep Power: 22 |
To find out what is possible in ParaView take a look at the options and play around with it. KitWare also release documentation, have you had a look at that?
May 23, 2005, 11:51 |
Yes I did, I have worked with
Rolando Maier
Rep Power: 17 |
Yes I did, I have worked with it from time to time.
What Iīve seen is, that one canīt do such "complex" data manipulation with the Calculator-filter. If one can do it nevertheless, I didnīt get it so far. To write filtered data explicitly, I didnīt try so far. |
