Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Total pressure in post-processing
Old   July 31, 2009, 03:59
Default Total pressure in post-processing
Marcin Hinz
Marcin is on a distinguished road
Hi everybody,
I have written a small post-processing tool, which gives me some values to compare my simulations with CFX. I simulate rotor and stator blades of a gas turbine with rhoSimpleFoam solver. One of my value which I need is total pressure. To calculate it I would like to use the formula:
ptot = p * pow ( ( (1. + (kappa-1.) / 2) * magSqr(Ma) ) , (kappa / (kappa - 1. ) )
where Ma is the Mach number and kappa is the isentropic exponent.
The problem is, that I can't get the value of kappa. I have tried to get Cp and Cv values and divide them, but these both values are volScalarFields and I can't use the pow function with it. Some ideas?
Best regards,
Marcin
Marcin is offline   Reply With Quote
total pressure change in a pipe flow Im FLUENT 5 February 23, 2017 08:55
Total and static pressure drop Janakiram Siemens 1 February 8, 2009 01:32
inlet total pressure c0384 Siemens 3 April 21, 2008 07:50
Total pressure and velocity inlet BC ff FLUENT 1 June 14, 2003 20:09
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
