Home > Forums > OpenFOAM Post-Processing
about Rayleigh numbe
Old   December 28, 2009, 08:49
Default about Rayleigh numbe
Nabil
vilop6 is on a distinguished road
hi all
how can i get or calculate Rayleigh number.
related docs: http://en.wikipedia.org/wiki/Rayleigh_number
best regards
vilop6 is offline   Reply With Quote
Old   December 28, 2009, 16:07
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
Originally Posted by vilop6 View Post
hi all
best regards
User your calculator.
Or try to give us some more details.
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   December 29, 2009, 10:39
Default about Rayleigh number
Nabil
hi sega
i want an utility tool, or some help to develop once to calculate Rayleigh number as field.
to do this i need
- rho field
- T field
- nu and alpha
Old   December 31, 2009, 05:09
sega's Avatar
Sebastian Gatzka
Do you have any knowledge about OpenFOAM programming so far, or are you a beginner?
Old   December 31, 2009, 09:08
Nabil
i am new in openfoam programming, do you think that openfoam programming guide is enough to write a small utility.
Old   December 31, 2009, 09:45
sega's Avatar
Sebastian Gatzka
No, I don't think so.
I suggest you take a look at the slides from the 4th OpenFOAM Workshop.
Especially the Basic Training slides should be of interest to you.
In particular these:
Have fun!
Old   January 4, 2010, 06:34
Nabil
thank you sega for your help and time
after reading this material i know how
-compile an solver
-add a new scalartransportproprieties like nu
-declaration of fields in creatfields.H
i hope to implement my own solver
but there is some thing i dont understand when
i tray to compile this equation inspired from programming tutorial
d(T)/dt + U*grad(T) = nu*laplacian(T)
i get some thing like this
[caelinux@localhost icoFoam]$ wmake
Making dependency list for source file icoFoam.C
SOURCE=icoFoam.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/caelinux/OpenFOAM/OpenFOAM-1.4.1/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/caelinux/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude -fPIC -pthread -c $SOURCE -o Make/linuxGccDPOpt/icoFoam.o
icoFoam.C: In function ‘int main(int, char**)’:
icoFoam.C:83: error: no match for ‘operator==’ in ‘Foam::fvm::laplacian(const Foam::volScalarField&, Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&) [with Type = double](((Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&)(& p))) == Foam:perator-(const Foam::tmp<Foam::GeometricField<Type, PatchField, GeoMesh> >&) [with Type = Foam::Vector<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh]()’
/home/caelinux/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/cellModelI.H:124: note: candidates are: bool Foam:perator==(const Foam::cellModel&, const Foam::cellModel&)
/home/caelinux/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/edgeI.H:147: note: bool Foam:perator==(const Foam::edge&, const Foam::edge&)
make: *** [Make/linuxGccDPOpt/icoFoam.o] Error 1
what that mean, if you know,
errors related to
operator==
operator+
Old   January 4, 2010, 06:38
sega's Avatar
Sebastian Gatzka
Well how did you actually implement the equation?
Can you show us some code?
How is this related to the Rayleigh number?
Old   January 4, 2010, 07:08
Nabil
the goal is to do some simulation for a specified Ra number 10E4 .. 10E7
Ra number is used in dimensionless "no dimonsioned" equations like here
http://www-cast3m.cea.fr/cast3m/html...35/node50.html
Ra=Gr.Pr
but open foam use a dimensioned equations
so i have two choice
use openfoam dimensioned equations and calculate Ra number after
or write a new solver " equation with no dimension by changing dimension parameters in SetDimension.H", i prefer this second coice because i can control Ra numbre and i dont have to calculate it
i guess
what do you think
ragards
Thread Tools
Trackbacks are On
Rayleigh Taylor simulation in fluent kamal Main CFD Forum 2 January 22, 2009 09:57
Fanno Rayleigh flow in pipes Dave Main CFD Forum 0 December 21, 2007 04:37
natural convection at high Rayleigh mauricio FLUENT 2 February 23, 2005 20:43
About Rayleigh parameter Hyun Main CFD Forum 0 November 2, 2004 09:11
Rayleigh Number Thomas P. Abraham Main CFD Forum 4 March 27, 1999 07:39
