Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
How to output other properties?
Like Tree9Likes
Old   April 23, 2012, 18:13
Default How to output other properties?
Wagner C. Galuppo
wagnergaluppo is on a distinguished road
I am using the OpenFOAM-210 and I Know that with foamCalc utility I can get the components of velocity and I also know how to get mach number and vorticity, but does anybody know how to output other variables such as viscosity, Reynolds number and etc?
thanks,
Wagner
wagnergaluppo is offline   Reply With Quote
Old   April 24, 2012, 02:42
akidess's Avatar
Anton Kidess
Viscosity will be written to the time directories if it's not constant, and you can plot it with paraview. You can also use paraview to calculate the Reynolds number. If you want a command line utility, you'll have to get your hands dirty.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   April 26, 2012, 23:51
Wagner C. Galuppo
Thank you for your reply. I'm ready to get my hands dirty. Even though my viscosity is constant, I would still like to know how to output it at each time-step. I would like to verify that I am getting the correct value for my viscosity. I'm using the rhoCentralFoam solver. This is the output of the "createFields.H" file:
13--> const volScalarField& mu = thermo.mu();
So what I did was change this file to something like this:
13--> volScalarField mu
14--> (
15--> IOobject
16--> (
17--> "mu",
18--> runTime.timeName(),
19--> mesh,
20--> IOobject::MUST_READ,
21--> IOobject::AUTO_WRITE
22--> ),
23--> mesh
24--> );
Then I recompiled and created a "mu" file at my "/0/" directory. But after I running, the other time directories do not have the mu property. It's not autowriting as ordered. For the Reynolds number I'm still having problems. Do you know of any documentation about the command line utility for this?
thanks,
Wagner
Old   May 1, 2012, 14:42
Default sutherland viscosity
Wagner C. Galuppo
Hi Akidess,
I followed your suggestion and set the viscosity to sutherland. Now that the viscosity is not constant, I would have expected it to write to the time directories like you suggested. Unfortunately, viscosity does not appear in any of the time directories.
Have I missed something?
Here is the output of my thermophysical properties
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      thermophysicalProperties;
thermoType      ePsiThermo<pureMixture<sutherlandTransport<specieThermo<eConstThermo<perfectGas>>>>>;
mixture
    // normalised gas
    specie
        nMoles          1;
        molWeight       50;
    thermodynamics
        Cv              1007.8039105;
        Hf              2.544e+06;
    transport
        As              1.67212e-06;
        Ts              170.672;
Old   May 1, 2012, 14:48
Default createfields.H
Wagner C. Galuppo
This is what I've specified in the createfields.H file
const volScalarField& psi = thermo.psi();
volScalarField mu
IOobject
"mu",
runTime.timeName(),
mesh,
mesh
Old   May 2, 2012, 03:39
akidess's Avatar
Anton Kidess
Which solver are you using? I'll try it out and see if I can get it to work.
Old   May 2, 2012, 12:36
Wagner C. Galuppo
I'm using the rhoCentralFoam.
Thanks,
Wagner
Old   May 16, 2012, 15:28
Wagner C. Galuppo
I figure it out.
Thank you,
Wagner Galuppo
Old   May 19, 2012, 05:09
akidess's Avatar
Anton Kidess
Sorry I couldn't help much, I got busy with other things. Can you add a post on how you solved the problem? It might help others in the future.
Old   May 24, 2012, 12:29
Wagner C. Galuppo
Actually I partly figured it out. I found the file "basicThermo.C" in (/opt/openfoam210/src/thermophysicalModels/basic/basicThermo/)
If you have look from the 201st until 213th line you will find this:
mu_
        IOobject
            "mu",
            mesh.time().timeName(),
            mesh,
            IOobject::NO_READ,
            IOobject::NO_WRITE
        mesh,
        dimensionSet(1, -1, -1, 0, 0)
I copied the directory (/opt/openfoam210/src/thermophysicalModels/basic/) to my workplace and I changed the name from /basic/ to /myBasic/.
in terminal:
$ cd /opt/openfoam210
$ cp -r --parents src/thermophysicalModels/basic/ /home/cfd02/OpenFOAM/USER-2.1.0/
$ cd ~/OpenFOAM/USER-2.1.0/src/thermophysicalModels/
$ mv basic myBasic
Next I edited line 209 in the file myBasic/basicThermo/basicThermo.C from:
IOobject::NO_WRITE
to
and saved and closed it.
Then I changed the 27th line in the file myBasic/Make/files from:
LIB = $(FOAM_LIBBIN)/libbasicThermophysicalModels
to
LIB = $(FOAM_USER_LIBBIN)/libbasicThermophysicalModels
Next I compiled the code:
$ cd ~/OpenFOAM/USER-2.1.0/src/thermophysicalModels/myBasic/
$ wmake libso
It works, if you run rhoCentralFoam will output mu and doesn't matter if it is constant.
The Problem is that I'm overwriting the main library basicThermophysicalModels instead of creating a new one.
Old   May 24, 2012, 19:20
Wagner C. Galuppo
I changed the last modifications for mu on line 209 (in myBasic/basicThermo/basicThermo.C) back to
IOobject::NO_WRITE
and doing so reverted to the original configuration of OpenFoam for basic thermophysical property. I recompiled it overwriting my last changes.
Now OpenFoam is using the original configuration, and so I try to make a new basic thermoPhysical model.
First, I reset mu to AUTO_WRITE (since I want to output mu).
Next, I changed line 27 in the file myBasic/Make/files from
to:
LIB = $(FOAM_USER_LIBBIN)/libmubasicThermophysicalModels
and compiled it with the wmake libso command.
Then I copied rhoCentralFoam solver to my workplace and renamed the directory from /rhoCentralFoam/ to /muRhoCentralFoam/, and after that in the new /muRhoCentralFoam/ directory I changed the file from rhoCentralFoam.C to muRhoCentralFoam.C.
$ cd /opt/opefoam210/
$ cp -r --parents applications/solvers/compressible/rhoCentralFoam/ $WM_PROJECT_USER_DIR
$ cd $WM_PROJECT_USER_DIR/applications/solvers/compressible/
$ mv rhoCentralFoam muRhoCentralFoam
$ cd muRhoCentralFoam
$ mv rhoCentralFoam.C muRhoCentralFoam.C
Next, in the /muRhoCentralFoam/Make/ directory I changed the file files from
rhoCentralFoam.C
EXE = $(FOAM_APPBIN)/rhoCentralFoam
to
muRhoCentralFoam.C
EXE = $(FOAM_USER_APPBIN)/muRhoCentralFoam
And the file options from
EXE_INC = \
    -IBCs/lnInclude \
    -I$(LIB_SRC)/finiteVolume/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/basic/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/specie/lnInclude \
    -I$(LIB_SRC)/turbulenceModels/compressible/turbulenceModel \
    -I$(LIB_SRC)/dynamicMesh/lnInclude \
    -I$(LIB_SRC)/meshTools/lnInclude
EXE_LIBS = \
    -lfiniteVolume \
    -lbasicThermophysicalModels \
    -lspecie \
    -lrhoCentralFoam \
    -lcompressibleTurbulenceModel \
    -lcompressibleRASModels \
    -lcompressibleLESModels \
    -lmeshTools
to
EXE_INC = \
    -IBCs/lnInclude \
    -I$(WM_PROJECT_USER_DIR)/src/thermophysicalModels/myBasic/lnInclude \
EXE_LIBS = \
    -lfiniteVolume \
    -lmubasicThermophysicalModels \
    -lspecie \
    -lrhoCentralFoam \
    -lmeshTools
Then I tried to compile it, but it cannot find -lmubasicThermophysicalModels, the solver compilation is not reading my new basic thermophysicalModel.
Copilation error message:
Making dependency list for source file muRhoCentralFoam.C
SOURCE=muRhoCentralFoam.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -IBCs/lnInclude -I/opt/openfoam210/src/finiteVolume/lnInclude -I/home/USER/OpenFOAM/USER-2.1.0/src/thermophysicalModels/myBasic/lnInclude -I/opt/openfoam210/src/thermophysicalModels/specie/lnInclude -I/opt/openfoam210/src/turbulenceModels/compressible/turbulenceModel -I/opt/openfoam210/src/dynamicMesh/lnInclude -I/opt/openfoam210/src/meshTools/lnInclude -IlnInclude -I. -I/opt/openfoam210/src/OpenFOAM/lnInclude -I/opt/openfoam210/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/muRhoCentralFoam.o
/opt/openfoam210/src/finiteVolume/lnInclude/readTimeControls.H: In function ‘int main(int, char**)’:
/opt/openfoam210/src/finiteVolume/lnInclude/readTimeControls.H:32: warning: unused variable ‘adjustTimeStep’
/opt/openfoam210/src/finiteVolume/lnInclude/readTimeControls.H:35: warning: unused variable ‘maxCo’
/opt/openfoam210/src/finiteVolume/lnInclude/readTimeControls.H:38: warning: unused variable ‘maxDeltaT’
g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -IBCs/lnInclude -I/opt/openfoam210/src/finiteVolume/lnInclude -I/home/USER/OpenFOAM/USER-2.1.0/src/thermophysicalModels/myBasic/lnInclude -I/opt/openfoam210/src/thermophysicalModels/specie/lnInclude -I/opt/openfoam210/src/turbulenceModels/compressible/turbulenceModel -I/opt/openfoam210/src/dynamicMesh/lnInclude -I/opt/openfoam210/src/meshTools/lnInclude -IlnInclude -I. -I/opt/openfoam210/src/OpenFOAM/lnInclude -I/opt/openfoam210/src/OSspecific/POSIX/lnInclude   -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/muRhoCentralFoam.o -L/opt/openfoam210/platforms/linux64GccDPOpt/lib \
	     -lfiniteVolume -lmubasicThermophysicalModels -lspecie -lrhoCentralFoam -lcompressibleTurbulenceModel -lcompressibleRASModels -lcompressibleLESModels -lmeshTools -lOpenFOAM -ldl   -lm -o /home/USER/OpenFOAM/USER-2.1.0/platforms/linux64GccDPOpt/bin/muRhoCentralFoam
/usr/bin/ld: cannot find -lmubasicThermophysicalModels
collect2: ld returned 1 exit status
make: *** [/home/USER/OpenFOAM/USER-2.1.0/platforms/linux64GccDPOpt/bin/muRhoCentralFoam] Error 1
I also tried replacing in the file /Make/options
for the original one
but it loads the main basic thermophysicalModel from OpenFoam.
Do you have any suggestions or ideas about how can I create this new basic thermophysicalModel and load it in my new solver, or what I am doing wrong?
Thanks,
Wagner Galuppo
mickbatti and S1mple like this.
Old   September 1, 2015, 08:49
Default Figured out?
  #12
Lisandro Maders
Lisandro Maders is on a distinguished road
IOobject::NO_WRITE
to:
rhoCentralFoam.C
to
muRhoCentralFoam.C
EXE_INC = \
    -IBCs/lnInclude \
EXE_LIBS = \
    -lfiniteVolume \
    -lspecie \
    -lrhoCentralFoam \
    -lmeshTools
to
EXE_INC = \
    -IBCs/lnInclude \
EXE_LIBS = \
    -lfiniteVolume \
    -lspecie \
    -lrhoCentralFoam \
    -lmeshTools
Thanks,
Wagner Galuppo
Hello Wagner,
did you figure out your issue? It would be good if you write what you have done then other people could make use of this knowledge as well. I am trying to make a very similar implementation and I am getting similar errors..
Regards,
Lisandro
Lisandro Maders is offline   Reply With Quote
Old   September 1, 2015, 10:04
Olivier
olivierG is on a distinguished road
You don't need to do this to output viscosity, just use the functions objects "writeRegisteredObject".
ex:
type writeRegisteredObject;
functionObjectLibs ("libIOFunctionObjects.so");
objectNames ("bananas");
outputControl outputTime;
outputInterval 1;
Here, "bananas" will give you the list of all registered object, replace by the one you want.
regards,
olivier
LuckyTran, hcl734 and anfaenger like this.
olivierG is offline   Reply With Quote
Old   September 1, 2015, 10:42
Lisandro Maders
Thanks for your tip Olivier, it seems much more straightforward and ease to get this value.
However, I am not able to find it working.
I put transportProperties instead of bananas but it does not write the nu field in any step.. (by the way,I think I am doing the basic things right. I put the "functions" subdict in the controlDict file, etc..)
Lisandro
Old   September 1, 2015, 10:49
Olivier
hello,
Yes, function object should be in controlDict.
First, run your solver with bananas => you will get an error message with the full list of possible object, and there is no bananas.
Then, pick up the good one (name here can be something::nu instead of nu)
regards,
olivier
Old   September 3, 2015, 09:10
Lisandro Maders
Hi Olivier,
Does it work even if my viscosity has a constant value in all points? Because it seems not to be working.. The maximum I got was having a nu file in the time directories when I created it as a volScalarField in the createFields.H file in the solver directory..
Regards,
Lisandro
Old   September 11, 2015, 09:24
Lisandro Maders
I solved it a couple of days ago, here is what I have done in order to make it:
I wanted to write the viscosity and Cp values any written time in the case folder.
1. In the createFields.H file:
volScalarField mu_output
    IOobject
        "mu_output",
        runTime.timeName(),
        mesh,
        IOobject::NO_READ,
    turbulence->mu()
and
volScalarField cp_output
    IOobject
        "cp_output",
        runTime.timeName(),
        mesh,
        IOobject::NO_READ,
    thermo.Cp()
2. In the solver.C file:
    while (runTime.run())
        runTime.write();
        mu_output = turbulence->mu();
        cp_output = thermo.Cp();
That worked for me! Later when I finish my project I will try to use the functionObject tool as recommended by Olivier. It seems much easier but I was not able to make it work! Thanks anyway!
Regards,
Lisandro
Kummi, shock77 and S1mple like this.
Old   December 14, 2015, 17:24
Default and Reynold's number
  #18
thunde47
thunde47 is on a distinguished road
I want to plot Reynold's number. Not, Reynold's number is dependent on velocity. So, all I should do is provide a formula to calculate Re in the code. Also, I am going to calculate Re with mag(U). Please suggest how to incorporate these features in the code. I will appreciate if replies are relevant to icoFoam solver.
thunde47 is offline   Reply With Quote
Old   January 5, 2016, 03:12
hcl734 is on a distinguished road
Hi olivier,
your approach using function objects seems quite comfortable and I can reproduce some results for the thermo:... properties.
But when I put thermophysicalProperties for function object names, there is no result at all.
It says writing thermophysicalProperties object in the log-file but there is no output.
Ok there seems to be a bug in this function since it manipulates the header of the thermophysicalProperties-Dict adding the thermoType{...} entries into the FoamFile-header.
Could you help me to figure this one out?
hcl734 is offline   Reply With Quote
Old   January 5, 2016, 03:40
Olivier
hello,
function object work only with registered object. So there is 2 solution:
1) the properties you want is an object => just use the fuctionObject
2) you need some coding, and create a custom solver
the part 2) is easy, so don"t be scare.
regards,
olivier
S1mple likes this.
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
error message cuteapathy CFX 14 March 20, 2012 06:45
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
lift and drag on ship superstructures vaina74 OpenFOAM Running, Solving & CFD 3 June 8, 2010 12:30
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 12:02
