Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Understanding the coordinates of sample utility
Old   March 25, 2010, 11:17
Default Understanding the coordinates of sample utility
vishwanath somashekar
vishwa is on a distinguished road
i am using sample utility to get the velocity data on a plane after my simulation is completed.
I make a quick 2 x 2 grid and ran the sample utility and was not sure where the data is actually saved.
Here is the sample dict and the blockMesh dict for your reference.
sampleDict
setFormat raw;
surfaceFormat vtk;
interpolationScheme cellPoint;
fields
U
sets
surfaces
constantPlane
type plane; // always triangulated
basePoint (5 5 0);
normalVector (0 0 1);
//- Optional: restrict to a particular zone
// zoneName zone1;
blockMesh
convertToMeters 1;
vertices
(0 0 0)
(10 0 0)
(10 10 0)
(0 10 0)
(0 0 1)
(10 0 1)
(10 10 1)
(0 10 1)
blocks
hex (0 1 2 3 4 5 6 7 ) (2 2 1) simpleGrading (1 1 1)
the output of the sample utility is below
# "U" FACE_DATA 8
# x y z "U"_x "U"_y "U"_z
1.66667 3.33333 0 0.003 0 0
3.33333 1.66667 0 0.003 0 0
6.66667 1.66667 0 0.003 0 0
8.33333 3.33333 0 0.003 0 0
1.66667 8.33333 0 0.003 0 0
3.33333 6.66667 0 0.003 0 0
6.66667 8.33333 0 0.003 0 0
8.33333 6.66667 0 0.003 0 0
How do I save the coordinates of cell centers?
Regards,
Vishwa
vishwa is offline   Reply With Quote
Old   March 25, 2010, 11:41
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
Does this mean you just want to have the velocities on the cell centers (and not on the points)?
Well, I guess this should be possible if you switch of the interpolation.
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   March 25, 2010, 11:45
Thanks for the response...I checked the switches that are present for interpolationScheme in sampleDict
cell, cellPoint and cellPointFace. And, I know that I can use cell to save the cell center values. But what I don't understand are the x and y coordinates it saves..
At least in the case that i just posted, the x, y coordinates don't match the cell centers.
any help?
Regards,
Vishwa
Old   March 25, 2010, 11:56
sega's Avatar
Sebastian Gatzka
Is this the case with 'cell' as interpolationScheme? Thats strange ...
Old   March 25, 2010, 12:51
Yes,
This is output when the interpolationScheme is set to cell. I changed it to cellPoint and the result is the same.
Regards,
vishwa
Sample Utility not working in OpenFoam 1.6 titio OpenFOAM Post-Processing 6 November 15, 2014 18:04
ICC compiler and sigFpe for sample utility cfdmarkus OpenFOAM Installation 3 June 25, 2010 14:31
Sample Utility not working in OpenFoam 1.6 titio OpenFOAM Post-Processing 0 February 5, 2010 12:12
Sample utility not working in OpenFoam1.5 dev titio OpenFOAM Post-Processing 1 December 10, 2009 02:38
Problem with sample utility roberthino OpenFOAM Post-Processing 6 August 23, 2007 15:29
