May 15, 2020, 15:27 |
how to plot contour of alpha=0.5 in matlab
Rep Power: 8 |
I want to plot the bubble contour using alpha = 0.5 in order to compare the bubble shape at various times in my simulation. I want to do this in Matlab by plotting various times on the same plot. I create the contour in Paraview and I save the coordinates of alpha=0.5 contour using File --> Save Data. The problem is that when I plot the coordinates in Matlab the points are joined differently to what I see in Paraview (see attached image). I have tried sorting the data but Matlab just fills the whole shape of the bubble instead of showing only the outline. Can someone please tell me how I can solve this problem or a better way to do this? |
May 15, 2020, 17:49 |
Herpes Free Engineer
Rep Power: 12 |
Not sure if you are aware of the current forum for the post - hence my message - might be better to raise this question in a MATLAB forum. Hope you find solution to ur problem.
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
May 16, 2020, 21:25 |
#3 | |
abdikerim kurbanaliev
Rep Power: 15 |
Have you used griddata function? |
October 26, 2020, 12:55 |
Rep Power: 6 |
Hi, I use the file 'surfaces' to extract 2D surfaces of the phase fraction from OpenFOAM transient results. I postprocess the data using MATLAB to plot contours of the phase fraction and make videos. I am wondering if I have to use the interpolation function 'griddata' to do so. The problem with 'griddata' is that it takes time to do the interpolation, e.g. a simulation with 100 time steps may take more than an hour to generate the video. Any suggestions?
matlab; bubble contour; |
Export/Import data contour plots with Matlab | meangreen | FLUENT | 11 | October 28, 2020 10:06 |
3D contour plot from matlab vectors | diggee | Tecplot | 1 | June 5, 2017 12:19 |
[General] 3D contour plot from matlab matrices | diggee | ParaView | 0 | June 2, 2017 10:41 |
Viewing the 3D plot in matlab | KaranG | Main CFD Forum | 2 | April 10, 2017 07:55 |
Matlab PP: Generating X-vel Contour Error Plot | Bennp2000 | FLUENT | 5 | March 4, 2011 15:58 |
