¿center of pressure and moments in interDyMFoam? |
March 17, 2010, 12:42 |
angel
Rep Power: 16 |
Anybody know if it is possible to calculate the center of pressure and moments in a multiphase simulation using interDyMFoam Best regards, |
March 17, 2010, 15:16 |
Sebastian Gatzka
Rep Power: 20 |
Can you tell me what a center of pressure and/or momentum is?
Schrödingers wife: "What did you do to the cat? It's half dead!" |
March 21, 2010, 07:53 |
forces, momoents about and specified center and center of pressure
angel
Rep Power: 16 |
I want to obtain the sloshing forces and moments to be compare with experimental data of an tank partially filled with water suspected to a sinusoidal lateral excitation in Y direction [A*cos(w*t)] In fluent it can be done by “reports>forces>...” I can calculate the forces by [patchIntegrate p walls] this generate the total forces in X Y Z [Time=15 Area vector of patch walls[0] =(5,51E-17 -8,75E-17 7,72E-19) Area magnitude of patch walls[0] = 1,01 Reading volScalarField p Integral of p over vector area of patch walls[0] = (-86,11 -305,32 3,18) Integral of p over area magnitude of patch walls[0] = 99687,5 ] But I don't know the moments about an specified center [in my case a point in the middle of the lower part of the tank, were I fixed it to the shaker using a 3 axle load cell, in order to measure the vertical forece (Fz), lateral force (Fy) and roll moment(Mx)] If you can help me I will be very gratefully Best regards, |
March 21, 2010, 07:58 |
Sebastian Gatzka
Rep Power: 20 |
I would try to have a look into the tool, which calculated the forces.
Maybe you will have to alter it, so it will output the values you want.
Ensight: Visualizing forces and moments | David | EnSight | 3 | December 19, 2012 13:47 |
Movie for static pressure | chouki | FLUENT | 2 | June 11, 2008 15:53 |
How to find the coordinates of center of pressure | Alexey | Siemens | 0 | February 1, 2007 10:37 |
Fluent-V5,Turbomachinery (stagnation pressure live its own life) | Alberto Tamm | Main CFD Forum | 19 | May 27, 1999 14:42 |
