-   OpenFOAM Post-Processing (http://www.cfd-online.com/Forums/openfoam-post-processing/)
-   -   sampling of a curved surface with distance-based coordinate? (http://www.cfd-online.com/Forums/openfoam-post-processing/75667-sampling-curved-surface-distance-based-coordinate.html)
johannesk May 2, 2010 16:53
I have a simulation of a turbine blade which I want to postprocess. I now liked to get the pressure values on the suction side and unfold the surface by transforming x and y into a distance from the leading edge. This exists for sample in form of the "axis distance" keyword/option for lines, but is there a simple way to do it for a whole surface?
If not can you point me to the code of a utility that I could use as a base? I had a look at the sample sourcecode, but couldn't find the code for the axis distance in lines.
thank you in advance,
Johannes
