Home > Forums > OpenFOAM Post-Processing
Velocity at each Gridpoint
Old   May 15, 2010, 12:03
Default Velocity at each Gridpoint
Rafael
daebel is on a distinguished road
Hi all!
I am post-processing OpenFoam output data with Matlab. What I need are the gridpoints and at each gridpoint the velocity. However, the output files that I get from the person who is doing the OpenFoam simulation are not easy to process. The gridpoints are listed well, no problems there. But the velocity field is splitted into so many different subsets (internalField, Inlet, Oulet,...) that it is an almost impossible task to assign one velocity to one gridpoint.
Is there a way (in OpenFoam) to output velocities for each gridpoint? Some check box or some command, I don't know...
Just so I get the gridpoints in an "nx3" array (n: number of gridpoints, 3: each direction) and the velocity exactly in the same format?
Thank you very much for your help!
Best regards
daebel is offline   Reply With Quote
Old   May 16, 2010, 05:42
Mark Olesen
olesen will become famous soon enough
Since OpenFOAM uses a control-volume method, the internalField represents the velocity for the cell, not the points.
You could use the volPointInterpolation class (http://foam.sourceforge.net/doc/Doxy...rpolation.html) to interpolate the cell-based volume fields into point-based fields. I don't know off-hand if there is a utility to do this, or if you'd have to add it in (to the solver or a standalone utility) by yourself.
olesen is offline   Reply With Quote
Old   May 16, 2010, 08:20
Rafael
Thank you very much, I'll have a look at it!
Thread Tools
Trackbacks are On
Velocity in Porous medium : HELP! HELP! HELP! Kali Sanjay Phoenics 0 November 6, 2006 07:10
Velocity Under-relaxation in SIMPLE type methods Matt U. Main CFD Forum 6 July 4, 2005 05:29
Variables Definition in CFX Solver 5.6 R P CFX 2 October 26, 2004 02:13
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
