read user's input for post-processing utility
Hi all,
I've been able to read input value for a pre-processing utility: Code:
int main(int argc, char *argv[]) Here's what I tried: Code:
void Foam::calc(int argc, char *argv[], const Time& runTime, const fvMesh& mesh) // Line 41 Code:
SOURCE=trace_max_vor_droite.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/usr/local/OpenFOAM/OpenFOAM-1.6/src/postProcessing/postCalc -I/usr/local/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude -IlnInclude -I. -I/usr/local/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/usr/local/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/trace_max_vor_droite.o Thank you, Pascal |
Somebody has suggestions?
Pascal |
Ideas/suggestions would be greatly appreciate
thank you |
