Home > Forums > OpenFOAM Post-Processing
Confirmation needed about calculation of divergence
Old   June 10, 2010, 18:55
Default Confirmation needed about calculation of divergence
Pascal
Pascal_doran is on a distinguished road
Hi all,
I created an post processing utility to calculate the divergence of U. I started with the 'vorticity' utility and just changed curl(U) for div(U). Then I compile it without problem.
But when I run the utility I got :
keyword div(U) is undefined in dictionary "/home/ag74290/OpenFOAM/ag74290-1.6.x/run/test/system/fvSchemes::divSchemes"
So I add the fellowing line div(U) Gauss linear to:
divSchemes
    default         none;
    div(phi,U)      Gauss linear;
    div(U)           Gauss linear;
in the /home/ag74290/OpenFOAM/ag74290-1.6.x/run/test/system/fvSchemes file and everything seems to work.
My question: Why do I need to add this line in the fvScheme file?
Thank you,
Pascal
Pascal_doran is offline   Reply With Quote
Old   June 11, 2010, 02:41
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
Originally Posted by Pascal_doran View Post
Hi all,
The div-operator needs a discretization-scheme (all operators do) and this is not
decided until you actually use it.
So when you call on any operator, it first looks for which scheme to use and then calculate the result.
N
niklas is offline   Reply With Quote
Thread Tools
Trackbacks are On
Divergence problem for species transport model MY FLUENT 3 January 11, 2014 05:46
MRF and Heat transfer calculation Susan YU FLUENT 0 June 2, 2010 08:46
Warning 097- AB CD-adapco 6 November 15, 2004 05:41
Divergence in conjugate heat transfer calculation Julie Polyakh CD-adapco 1 May 18, 2004 13:09
DIVERGENCE with MRF calculation in FLUENT FLUENT USER Main CFD Forum 3 June 28, 1999 15:44
