-   OpenFOAM Post-Processing (http://www.cfd-online.com/Forums/openfoam-post-processing/)
-   -   Mass Flow rate through a plane (http://www.cfd-online.com/Forums/openfoam-post-processing/78435-mass-flow-rate-through-plane.html)
titio July 21, 2010 17:08
Hi foamers,
I am starting to feel desesperate guys. I am trying to calculate the mass flow through a plane that it is not a patch, as the massCalcFlow does. Is there any way of this the easy way, say using foamCalc or some other utility that I am not aware of. If not possible to do that easily, I will do it in the code, and I will contribute it to the community, if I manage to do it.
Can anyone help me out. Thanks in advance,
António Martins
PS: OpenFOAM really needs a good documentation, but it seems capitalism and common good do not mix very well... and the problems with the documentation site only helped the commercial software even more....
olesen July 22, 2010 02:20
Originally Posted by titio (Post 268402)
Hi foamers,
I'd guess that there just isn't a generic place for such a massflow sampling and that's why it hasn't made its way into the code.
Note that this is all much easier when sampling on a patch, since you can simply use the phi directly there.
Nonetheless, this code fragment should give you a few ideas (I hope).
// defined somewhere in the surrounding class:
PtrList<sampledPlane> gammaPlanes_;
void Foam::massFlowInfo::calculateAndWrite
    const volVectorField& U,
    const volScalarField& rho
) const
    forAll(gammaPlanes_, planeI)
        const sampledPlane& pln = gammaPlanes_[planeI];
        label nFaces = pln.faces().size();
        reduce(nFaces, sumOp<label>());
        if (nFaces)
            // the velocity normal to the plane
            scalarField Uproj = pln.project
                pln.sample(U)
            scalar U_mean = pln.average(Uproj);
            scalarField rhoU = pln.sample(rho) * Uproj;
            scalar massFlow = pln.integrate(rhoU);
            Info<< pln.name() << nl
                << "  area      = " << pln.area() << nl
                << "  massFlow  = " << massFlow << "  ("
                << (massFlow * 3600) << " kg/h)" << nl
                << "  U_mean    = " << U_mean
                << endl;
        else
                << "  area      = " << 0
                << endl;
titio July 22, 2010 13:23
Thanks
Thanks olesen. I will try the code and I will let you know if its worked.
Thanks,
Titio
chegdan October 26, 2010 16:54
what happened with this?
Was this resolved? if so, please share how you made this possible.
robingilbert October 26, 2010 17:00
try swak4Foam:
http://openfoamwiki.net/index.php/Contrib/swak4Foam
to calculate flow rate through internal faceZone this works. i have tried it. to calculate the flow through a patch u can use calcMassFlow:
http://openfoamwiki.net/index.php/Contrib_calcMassFlow
maysmech October 27, 2010 16:59
hi,
How can i calculate mass flow rate of a patch by using paraView software?
misakagan March 25, 2012 19:08
how to construct sampledPlane?
) const
        if (nFaces)
                pln.sample(U)
                << endl;
        else
                << "  area      = " << 0
                << endl;
Dear Mr. Olesen,
The code is very helpful, but I wonder also how the parts related to construction of sampledPlane's is implemented. Normally sampledPlane's are constructed on runtime using the sampleDict with runtimeselectiontable. I don't know how to construct them in a regular way with the direction vectors and basepoints.
Any suggestion would be a lot of help.
Best,
Asim
misakagan March 25, 2012 19:41
Ok I found the answer. I have to create cuttingPlane's and construct sampledPlane's using those cuttingPlane's...
