May 25, 2009, 05:57 |
Conversion of Data file to FLUENT
Sanjib Das Sharma
Rep Power: 16 |
I am new to OpenFoam, actually today is my first day. Howwever, I have been using FLUENT for almost 10 years now and know the software very well. It would be a huge plus for me if the OpenFoam data can be exported to FLUENT for post-processing. I tried using the command "foamDataToFluent", but the conversion did not take place. Is there any other way to do the conversion ? By the way, I tried to use Paraview initially. It looks too complicated to even for simple post-processing. Regards, Sanjib |
July 21, 2009, 05:21 |
isabel
Rep Power: 17 |
I have the same situation as you. I know very well Fluent, but OpenFOAM since a couple of months.
foamDataToFluent works. You have to type foamDataToFluent fluent.msh |
April 21, 2011, 02:37 |
what can you get from Fluent with "CFD General Notation System" (CGNS)? http://www.cfd-online.com/Forums/ope...available.html If you can export the Fluent results to CGNS?! |
September 9, 2011, 06:13 |
hello every one
hii
I m new user of openfoam 200 so i have some problem arise when i write foamDataToFluent it cant run so how can i convert my foam data in to fluent file |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
OpenFOAM Install Script | ljsh | OpenFOAM Installation | 82 | October 12, 2009 11:47 |
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise | mbeaudoin | OpenFOAM Installation | 20 | June 17, 2008 06:43 |
Regarding FoamX running Kindly help out | hariya03 | OpenFOAM Pre-Processing | 0 | April 18, 2008 04:26 |
